403 forbidden - what`s this all about?
Holy crap, you're still on Windows 3?? Your ID string indicates NT 3.51 and Firefox 2.0.
I think the message is self-explanatory. You're running (or it thinks you're running) a very outdated browswer version that isn't maintained, and has known security flaws. That makes it a very dangerous browswer to use, because it could be compromised in any number of different ways.
I don't usually use the old NT but I've never seen another site that had a blanket ban on old browsers. (A lot of sites won't work right, but that is different than showing a giant error message, and most forums work fine.) It seems pretty arbitrary and I don't know why you would care. How much malware is targetting NT 3.51? More importantly, user agents can be spoofed.
- Beamter
I can't say for certain the reasoning behind it, but FF 2.0 is ancient. When it comes to site security, I largely defer to Justin's judgement. We've had relatively few issues from a security standpoint, and I'd prefer to keep it that way.
You must have a more modern machine you can use for browsing the site, don't you?
- Beamter
Well, I mostly disagree with this. It's reasonable for sites handling financial transactions and the like to block unsecure clients. Otherwise I don't think old hard/software should be deliberately blocked anymore than old cars should be banned from the road. But I'm not going to tell you guys how to run your site.mooseheadm5 wrote:http://chris.pirillo.com/should-web-sit ... -browsers/
FYI, I was only on NT3.51 "because I can." I have it setup to dual-boot on an XP machine and occasionally test FreeBASIC code on it.
- Beamter
Another issue is that if the site does not work properly on older browsers, we will get complaints that the phpbb stuff is broken, when the problem is just your antique software.
In many states, busted old cars that aren't fit for the road are not allowed.
Also, the reason given in the 403 notice is pretty explanatory. Hackbots and spambots often use older protocols because of the exploits that can be used.
- Beamter
His is very specifically due to his browser. Yours could be that the ip address your phone uses could be part of a banned block. If you can get that IP address and tell Justin, he can unblock it if that is the issue or just post the screencap. I don't have a problem with Safari on the ipad.Kyle in NO wrote:I get the same bullshit Forbidden message all the time on my iPhone using the most up to date Safari browser. I don't think it has anything to do with his old ass browser.
Again, read the actual message.12valves wrote:Well, I mostly disagree with this. It's reasonable for sites handling financial transactions and the like to block unsecure clients. Otherwise I don't think old hard/software should be deliberately blocked anymore than old cars should be banned from the road. But I'm not going to tell you guys how to run your site.
I'll quote:
"The detected reason(s) you were blocked are:
You are running a severely outdated version of Firefox which matches a hackbot or spambot profile."
As I stated earlier, those older browsers are very vulnerable. Any flaws they have are not going to be patched. Ever. This makes them attractive targets for people running spambot networks.
Ever wonder why you don't see a ton of spam on this site? First off, it's because we kill it with fire when it pops up. Second, we do what we can to stop it from getting in to begin with.
All this over an issue that really doesn't affect you much at all. Kyle's issue is actually more concerning. Screen cap the error you get and post it, please, Kyle.
- Beamter
That IP appears to have recently expired out of the StopForumSpam database, refreshed the cached copy on the server so it should be clean. You were only blocked from login functions and shouldn't have experienced problems browsing as a guest.Kyle in NO wrote:Here is what I keep getting, mixed in with Safari telling me the page is not available.[/img]
Cell phone networks are dirty and a growing preference for spammers/hackers in the US as an Internet connection, so it is likely that IPs shared amongst many subscribers can and will get blocked...
I did turn on a function on the error page that should allow innocent users to compose an email with the block details so it is easier to report false positives.
When that pops up, I am not even able to access the basic www.mye28.com web page as a guest.
Edit:
Maybe I screen cap'd that message during a login attempt. I'll send one of the other message when it happens again.
Edit:
