Page 1 of 8
Holy Grail Labs - M30B35 Intake Manifold Bracket
Posted: Jun 23, 2014 5:10 PM
by tig
New production coming soon! Subscribe to this thread to be notified when they are available.
The M30B34 intake manifold is supported by two struts that bolt to the valve cover and a small bracket between the block and the bottom of the manifold.
The M30B35 does not have those ugly struts above and is instead supported by a beefy aluminum bracket connected to the engine mount.
The shape of the E28 engine mount prevents the aluminum M30B35 bracket from fitting.
Here's what a B35 looks like:
This pic shows the M30B34 bracket, along with the correct motor mount. The B34 bracket will not be as strong; on the B34 there are additional supports holding the manifold in place at the top of the manifold.
This is the problem: The motor mount is in the way of the M30B35 bracket:
This bracket needs to be about 23mm ‘shorter’ so that the nut for the engine mount can secure it above the mount (top right hole).
Other's have butchered both the engine mount bracket and the intake bracket to make this work. I'm not into butchering such things.
I also know the intake manifold is not likely to break on it's own. However, I am not ok with not having it supported. I figure some idiot some day may attempt to leverage the engine with the mainfold...which is probably why BMW designed it so heftily (sp?).
Planned design (may change as I refine the design):
Re: Need Fabricated: Bracket for B35 Intake Mainfold
Posted: Jun 23, 2014 10:06 PM
by athayer187
I'm no help other than to offer to buy a second if someone is putting in the time and effort!
Posted: Jun 23, 2014 10:26 PM
by Bimmerguy2002
mill the head 23mm, it will give higher compression, duh.
Posted: Jun 23, 2014 10:41 PM
by tig
Bimmerguy2002 wrote:mill the head 23mm, it will give higher compression, duh.
Scotch just came out my nose.
Posted: Jun 24, 2014 2:32 AM
by tig
Ok, this is cool.
Thanks to @M635CSi I have discovered
http://www.emachineshop.com
Within about an hour in their CAD software I have it basically done:
I have to verify one measurement. Single piece made of steel will be $137 with shipping.
Out of 5052 aluminum $132.
I know nothing about materials, so I'm going to do some more digging.
But with a quantity of 10 they are about $20 each...
Posted: Jun 24, 2014 2:49 AM
by Brian D
Make that happen and I'd be in for one.
Posted: Jun 24, 2014 9:46 AM
by az533
Count me in for 1.
Posted: Jun 24, 2014 10:41 AM
by tig
Using 1/8" steel and powder coated the price per goes up to $30.
While using the CAD app I discovered that my geometry wasn't quite right. I need to mock it in cardboard and test fit it before pulling the trigger, but I'm 99% sure I'm going this route to get it done.
Maybe I'll be able to quit my real job.
Posted: Jun 24, 2014 11:21 AM
by tig
Cardboard mock-up. Just a few tweaks needed!
Posted: Jun 24, 2014 12:44 PM
by TheGraye28
List?
1. athayer187
2. az533
3. BrianD
4. TheGraye28
5. Sleeper21
Posted: Jun 24, 2014 1:23 PM
That looks like corrugated cardboard so it should be plenty sufficient if the corrugations were going up/down.
Posted: Jun 24, 2014 2:04 PM
by Bimmerguy2002
cek wrote:Bimmerguy2002 wrote:mill the head 23mm, it will give higher compression, duh.
its like you dont even want 178:1 compression man....
Posted: Jun 24, 2014 3:31 PM
by Sleeper21
TheGraye28 wrote:List?
1. athayer187
2. az533
3. BrianD
4. TheGraye28
I'll take one, let me know payment info- thanks Scott
Posted: Jun 24, 2014 4:11 PM
by TheGraye28
Updated
Re: Taking Orders: Bracket for B35 Intake Mainfold
Posted: Jun 24, 2014 4:30 PM
by Ron535i
I'm in for one...
1. athayer187
2. az533
3. BrianD
4. TheGraye28
5. Sleeper21
6. Ron535i
by tig
I have changed this thread from a "Wanted" ad to a "I'm actually going to do this and jump on board if you want" thread.
To be clear: I do not know the final price per bracket yet. Until I finalize the design (I have some tweaking to do to be 100% sure it will fit...it would really suck for it not to) I won't know the upper bound. It's probably close to $30 (+ shipping). If we get significantly more than 10 people interested the price will head South. The economics of this are such that it probably only makes sense to do this once.
Thanks for all the encouragement so far. This should be fun.
Posted: Jun 24, 2014 4:45 PM
by tsobrado
I will jump in as well. One for tsobrado.
CEK, I remember your FJ40 from another forum. That was a nice FJ but your current project awesome. I have learned a lot from you.
Posted: Jun 24, 2014 5:33 PM
by fries_man
In for one.
Posted: Jun 24, 2014 6:35 PM
by tig
tsobrado wrote:I will jump in as well. One for tsobrado.
That's a scary thought.
Posted: Jun 24, 2014 7:28 PM
by PDX5
I'm in for one bracket.
Posted: Jun 24, 2014 7:35 PM
by tig
PDX5 wrote:I'm in for one bracket.
And the price just started going down. Cool.
Posted: Jun 24, 2014 8:04 PM
by tig
Question: Would people prefer these powder coated or plain metal?
The # of colors available from emachineshop is limited and the Aluminum that I used on all my other parts is not one of them. It is hard to tell what their gloss gray or gloss black actually looks like, so there's some risk. The per-piece cost goes down sans-powder coat, but buyers would be responsible for final finishing.
I *could* get them zinc/cadium plated after the fact; the place I used (arrowplating.com) is very reasonable. Something to consider.
Let me know your opinion.
Posted: Jun 24, 2014 10:16 PM
by athayer187
I'm in for any version.
Posted: Jun 25, 2014 12:10 AM
by Brian D
No to powdercoat, Zinc/cad or bare is my preference.
Re: Taking Orders: Bracket for B35 Intake Manifold
Posted: Jun 25, 2014 2:55 AM
by tig
1/8" steel is pretty beefy. This bracket will be super strong, I believe.
FWIW, the current steel I have selected is "1008/1018/Commercial Quality, Cold rolled".
Here's a design that is actually slightly less expensive (apparently because the removed material makes the bend easier).
Thoughts?
