New quirk on occasion
Every so often lately I've been getting the message below. Usually at work which I blew off since all sorts of weird things happen there with the way they run things, but even at home now where things usually run quite well. Usually it results in a double post but not always.
Re: New quirk on occasion
Mike W. wrote:Every so often lately I've been getting the message below. Usually at work which I blew off since all sorts of weird things happen there with the way they run things, but even at home now where things usually run quite well. Usually it results in a double post but not always.
+1
I've had that too but I felt honored to see the General. If it was Major Error, I'd think I wasn't being respected.
Ditto. And it looks like it was part of the refresh process because I've opened another browser window to confirm that the post was made despite the error, it's the recovery that chokes. My guess is turnitoffturnitbackonagain will fix it.
waynet1
Post by waynet1 »
ahab wrote:Ditto. And it looks like it was part of the refresh process because I've opened another browser window to confirm that the post was made despite the error, it's the recovery that chokes. My guess is turnitoffturnitbackonagain will fix it.
Me too.
If you walk away from the error and come back some amount of time later, it's allll gone and better again.
Typical computer shit that just plain old doesn't work right. Just another one of those.......that's just the way it is...... :roll:
WilNJ
Post by WilNJ »
Not sure thats it related but TapaTalk hasnt worked for the last day or two.
Yeah and then the "Thread of Randomness" had this gay Madonna title yesterday too. . .
Justin_FL
MyE28 IT Guru
MyE28 IT Guru
Post by Justin_FL »
Mike W. wrote:Image
Can anyone tell me when they began seeing this error? A couple days ago, one week, three weeks ago, etc?
Justin_FL
MyE28 IT Guru
MyE28 IT Guru
Post by Justin_FL »
WilNJ wrote:Not sure thats it related but TapaTalk hasnt worked for the last day or two.
I only removed it yesterday morning, with a suspicion that it might have caused the issue. An update to a newer version on Dec 2nd is the only change I recall making in the past month.
So this morning I removed/reinstalled Tapatalk and just got another uglier bug with my post above...
Did anyone see the errors from 9:45am Fri to around 11am Sat? The Tapatalk forum plugin was removed during that time.
geordi
Post by geordi »
Have been getting same error on most of my posts. Just happened again. Post does go thru and reopening fixes.
I'd say about a week ago when I saw the first one.
Since at least Dec 2nd, which is when I told you about it. ;)
(in total fairness, Justin said he couldn't reproduce the error on his end at the time)
carnutdallas
Post by carnutdallas »
I searched, but this thread is all I have found. What is the status of Tapatalk? I love using it and it is my main source of contact and updates. Please advise. Thanks!
WilNJ
Post by WilNJ »
Some what unrelated but on the topic of TapaTalk, its almost as if mye28.com is a subforum within its self. Is there a reason for that?
Justin_FL
MyE28 IT Guru
MyE28 IT Guru
Post by Justin_FL »
WilNJ wrote:Some what unrelated but on the topic of TapaTalk, its almost as if mye28.com is a subforum within its self. Is there a reason for that?
Just the way Tapatalk displays things, but it is the same within a web browser although less obvious. These are the other upper level categories, but most people can only see "MyE28 Forums" categories. I renamed it to "Discussion" so you don't see MyE28.com -> MyE28.com Forum -> Tech Talk (etc).
