I weld
I weld
I've had a Lincoln AC-255 stick welder for many years. Bought it on CL. Turned it on once to make sure it actually worked.
Today I started teaching myself how to weld. I've been reading a welding book and about 4 years ago my son I took a half day class. I started by just trying things with some 3/16" steel I had lying around and some E6013 1/16" electrodes.
Then I got serious and watched some youtube videos. I also discovered that I hadn't removed the protective plastic sticker on the inside of my auto-mask. Turns out it's a lot easier to weld if you can see.
Starting to get the hang of it. I have a long way to go, but I've now drawn enough beads that I can actually control things.
Fun, fun, fun.
Re: I weld
cek wrote:Weld, ergo sum
I've long thought about a welding class..
I like the learning curve I'm seeing.
jjcarr
Re: I weld
Post by jjcarr »
This is definitely on my todo list.
bkbimmer
Re: I weld
Post by bkbimmer »
I'm closing my shop, so if you are interested in some welders let me know.
Re: I weld
bkbimmer wrote:I'm closing my shop, so if you are interested in some welders let me know.
Are you included?
muleskinner
Re: I weld
Post by muleskinner »
therefore I am
bkbimmer
Re: I weld
Post by bkbimmer »
Are you included?
For the right price.
Re: I weld
Today I practiced more. Got to the point that I felt I could pull a bead straight and true every time.
So I doubled down and decided to actually build something. I don't have any material to actually build something I'd USE, like an engine cradle, but I did buy 6' of 1" square tubing at home depot.
So I decided to make a little 8"x8" square. Totally useless, but would require many skills I don't have.
Using my bitch'n Hemsaw, I was able to cut 4 equal size pieces.
I failed to consider three things:
1) The 1/16" thick 1" square tubing is a lot thinner than the 3/16" stuff I was practicing with.
2) Butt joints make burn-through happen real quick now.
3) The lowest (40 amp) setting my a Lincoln arc welder is still to hot for 1/16" steel unless you are a pro (at least that's what I'm telling myself).
So, my little square got built, but it ain't pretty.
Oh, well. This is how one learns.
bkbimmer
Re: I weld
Post by bkbimmer »
Why would you waste your time with a stick welder?
Re: I weld
bkbimmer wrote:Why would you waste your time with a stick welder?
Because you haven't sold me your mig yet.
bkbimmer
Re: I weld
Post by bkbimmer »
I could teach you how to be a professional mig welder in about 15 minutes.
joel323
Re: I weld
Post by joel323 »
https://seattle.craigslist.org/see/tls/5458448331.html
Price is a little high but a nice machine
Re: I weld
joel323 wrote:https://seattle.craigslist.org/see/tls/5458448331.html
Thanks.
The new Miller 211 looks really nice, but from reviews seems their quality has gone down.
http://www.amazon.com/Millermatic-211-W ... B013HGPNDM
Meanwhile, I have this in my Amazon wish-list. Great reviews, a lot less expensive, and still made in 'murica.
http://www.amazon.com/dp/B004USV5UC
Re: I weld
Good progress. Get a decent mig, learn how to adjust the settings correctly for the material and you'll be surprised at how quickly you'll improve. Remember, just like the porn, welding is all about the penetration.
brickwhite
Re: I weld
Post by brickwhite »
I like my cheap hobart, it does what I need for under $500.
http://www.amazon.com/gp/product/B009X4 ... =8-1-spell
joel323
Re: I weld
Post by joel323 »
Miller owns Hobart I believe, One thing to keep in mind about the current Hobarts is that they do not have the infinitely variable power switch. . Miller models and some Lincoln models have this feature. This makes a big difference when your tuning your welder.
bkbimmer
Re: I weld
Post by bkbimmer »
I have thousands of hours on my miller 210 and never had a problem with it, only need to replace wear items like liner and tips.
I'm about ready to buy a new stinger for it after 10 years.
mitch5
Re: I weld
Post by mitch5 »
Just make sure to get a mig that runs off 220v, unless you want to weld other metals than steel, a used lincoln mig setup is what i would recommend. I use a 10 year old lincoln and it works great, a big plus is that home depot sells lincoln spool wire and consumables. Heres an example of how you could put together a complete setup for less than $400. https://phoenix.craigslist.org/evl/tls/5454150731.html
Another tip is when you go to buy a cO2 tank call around and ask steel supply yards if they sell tanks, i found that all the gas companies like praxair will make you pay out the nose if your not a business. for example they quote $350 for a 150cf and a steel yard will sell a 220cf for $200.
bkbimmer
Re: I weld
Post by bkbimmer »
mitch5 wrote:Just make sure to get a mig that runs off 220v, unless you want to weld other metals than steel, a used lincoln mig setup is what i would recommend. I use a 10 year old lincoln and it works great, a big plus is that home depot sells lincoln spool wire and consumables. Heres an example of how you could put together a complete setup for less than $400. https://phoenix.craigslist.org/evl/tls/5454150731.html
This guy can afford a good welder and bottle. :lol:
Not that you asked for any opinions but since this is a forum...
I would buy a machine that exceeds anything you think you will do so you never have to upgrade. I rarely use even 50% of my machines capacity which means it never reaches it's duty cycle. I understand you aren't doing this for a living but if you can afford it why not. When I was starting out at around 16 all I could afford was a 110v sp125 Lincoln which was awesome but I was almost always using it near max capacity and it made working a pita and the work suffered on anything above 14g.
Beyond the machine the best thing you can do is invest in a good helmet.
Re: I weld
nice job Man! something i need to learn.
how's that s52 swap coming along? would be great to see some updates :poke:
Re: I weld
joel323 wrote:Miller owns Hobart I believe, One thing to keep in mind about the current Hobarts is that they do not have the infinitely variable power switch. . Miller models and some Lincoln models have this feature. This makes a big difference when your tuning your welder.
I hear you on that. Bummer if you want aluminum spool gun capability you have to go all the way to the Miller 212 (which is 220v ONLY). But that Hobart will work with a spool gun and is 110/220. But the Miller 211 is infinitely adjustable and the Hobart only has 7 settings.
I don't know enough to really know if the infinitely variable power is that critical... you seem to think it is and I have a high-regard for the results you produce so...
(This, BTW, is precisely why I've started with stick: I had one and didn't want to make the decision on a MIG until I actually had some experience).
bkbimmer
Re: I weld
Post by bkbimmer »
My older miller 210 excepts a spool gun but if you want to weld aluminum you might as well get a tig welder. Spool guns are mostly good for large fabrication as you cant get them in tight places.
Re: I weld
Actually, it turns out I just missed that the 211 will work with a spool gun. Good point on doing aluminum right.
bkbimmer
Re: I weld
Post by bkbimmer »
No shit, I'm a fucking professional.
Pavel
Re: I weld
Post by Pavel »
One of the skills I am happy I am getting better at. I am just being cheap and using a HF flux core wire welder.
