e34 big brake kit (rotors, pads, master, calipers)
Bimmerguy2002
Post by Bimmerguy2002 »
Need 15 inch OEM wheels minimum to clear.
Both sets from e34 540i, rotors have correct offset for e28 and everything is a direct bolt on. All rotors smooth, no pitting, no ridges, with no lip, solid rotors had surface oxidation and steel wool taken to remove. Slotted and cross drilled rotors were cleaned with degreaser and brakleen with soft wire wheel, could probably use a little more cleaning but fine to slap on.
Pads have about 80% of material left.
Both come with a 25mm master cylinder, or 3mm bigger than factory.
Have other sets of same calipers too.
550 for solid rotor set
600 for slotted/cross drilled set (SOLD)
Shipping for each BBK 75 via USPS 3 flat rate boxes.
click to make bigger
Buyer beware, i do not accept returns or refunds under any circumstances, ask necessary questions before purchasing.
Paypal gift, zelle, USPS money order, or check. If local then biden bucks.
Punnzzells
Re: stage 5 big brake setup
Post by Punnzzells »
Do you need to do the e34 master cyclinder and brake booster too with this upgrade or can that be done later on?
Punnzzells wrote: Jul 27, 2023 10:34 AM Do you need to do the e34 master cyclinder and brake booster too with this upgrade or can that be done later on?
It's an E32 MC, and no it's not necessary. The E32 MC will change the pedal action by reducing the pedal travel and feel; it doesn't make it worse, just different. And yes it can be changed later if you want to.
kkeys2001
Re: e34 big brake kit (rotors, pads, master, calipers)
Post by kkeys2001 »
Interested. Still available?
Bimmerguy2002
kkeys2001 wrote: Oct 21, 2024 8:27 PM Interested. Still available?
I do have another set with two varieties of rotors. Regular rotors and another with slotted rotors.
https://ibb.co/J2n2D7c
https://ibb.co/8BqZyRY
They are indoors and just have surface oxidation from sitting there, will clear off with steel wool.
Edit, I have calipers, pads, and master with them too.
