Instrument cluster gear position indicator bulb replacement and size/tpe????
Posted: Nov 27, 2023 10:38 AM
by blockerb
general question. I have a 1986 528e automatic. The "Park" indicator bulb in the instrument cluster has gone out. All the others work fine. Is this a removable/replaceable bulb? If so what size? I'm thinking a 12v, 1.2w mini/wedge type bulb but the specs on realoem.com don't say.
Re: Instrument cluster gear position indicator bulb replacement and size/tpe????
Posted: Nov 27, 2023 12:26 PM
IIRC and Realoem seems to back me up, it's a bar (mini PC board) with all the gear indicator lights soldered onto it. #5 in the diagram. I don't think the bulbs are available individually, at least not from BMW.
Posted: Nov 27, 2023 12:45 PM
by Blue Shadow
The bulbs are soldered in and are available from any gear position indicator cluster that is not in use. Generally all the bulbs except P and D will be fairly fresh and worth swapping. I've done this for someone's cluster. It is a little fiddly but not that hard if you are careful and know how to solder.
Gonna be a lot cheaper than buying a new indicator cluster.
Posted: Nov 27, 2023 1:11 PM
by Aldo525
blockerb wrote: Nov 27, 2023 10:38 AM general question. I have a 1986 528e automatic. The "Park" indicator bulb in the instrument cluster has gone out. All the others work fine. Is this a removable/replaceable bulb? If so what size? I'm thinking a 12v, 1.2w mini/wedge type bulb but the specs on realoem.com don't say.
When I bought my automatic euro 525i the entire gear indicator was not working and when I took it apart I saw that the D shift had a 12v 1.2 w mini bulb soldered on (like #15 in Mike's diagram) and it works perfectly.. ...the mini bulb costs cents
Posted: Nov 27, 2023 11:15 PM
by Blue Shadow
Aldo525 wrote: Nov 27, 2023 1:11 PM 12v 1.2 w mini bulb soldered on (like #15 in Mike's diagram)
#15 is a 3W bulb and will not fit but a 12V1.2W might fit just fine.
Posted: Nov 28, 2023 5:35 AM
by Aldo525
Blue Shadow wrote: Nov 27, 2023 11:15 PM
You are right, my mistake....I mean the small bulbs like the ones used on "park brake", "fog lights", "ABS", etc....12V 1,2W. This kind of mini bulb is just a little more longer than the original used in the plate but fits perfectly.
Posted: Nov 28, 2023 6:48 AM
by Shawn D.
Quite specific question. :lol:
Posted: Nov 28, 2023 12:55 PM
by blockerb
Shawn D. wrote: Nov 28, 2023 6:48 AM
hah. true. I guess general in the sense that was just wanting to know if it was replaceable. AS with all things on this board, things get really specific really quick. :laugh:
Posted: Nov 30, 2023 9:10 PM
by shallam
I replaced the burned out lights in my gear indicator board by soldering in these: https://www.amazon.com/gp/product/B074S ... =UTF8&th=1
After 2 years and 6,000 miles, they are working fine. I replaced all of the bulbs on the board with these since I was already in there.
