Page 1 of 2
New Alternative to Factory Heater Valve
Posted: May 07, 2024 9:02 PM
by LarryM
I saw these advertised on Facebook. Looks promising, price is reasonable and looks better than kluging an E46 heater valve onto an E28 firewall. Has anybody actually purchased one and tried it out?
https://klimakit.com/product/bvx5/?fbcl ... V_gHp5tN7R
Re: New Alternative to Factory Heater Valve
Posted: May 07, 2024 9:16 PM
by Shawn D.
I saw that as well. I'm interested to see folks' long-term reports!
Posted: May 08, 2024 1:27 PM
by Philo
Pretty cool but pricey. Aren't there options from other models ?
Posted: May 08, 2024 3:38 PM
Philo wrote: May 08, 2024 1:27 PM
Yeah, that thought crossed my mind. If it was for a Ford pickup truck it would probably be $29.95. But it isn't and the factory one, which people have been having lots of problems with, is around $400. So in that light it's not that expensive. Probably 5K in development and it now costs ten bucks to make if they make enough of them. But just how much demand is there for 80s BMW heater valves?
Posted: May 08, 2024 4:15 PM
by Federico
Correct me if I'm wrong, but it seems to me the body is a 3d printed piece.
It would be interesting to know which process and material was used.
Posted: May 08, 2024 4:49 PM
by LarryM
A guy on the E28 Facebook page bought one and seems to like it a lot. Says it’s a perfect fit and functions fine. I wonder about the longevity. But I’m hoping for the best.
Shame on BMW for foisting those crappy Chinese-made heater valves on us; I’ve gone through three of them in as many years. They only warranty it once; if you have to replace a new one that failed within 12 months, that replacement won’t be covered when IT fails. They don’t seem to care about correcting what is obviously a quality control issue.
Posted: Aug 16, 2024 2:04 PM
by MisterFixit
Hey, just a thought that has occurred to the 'Inventor' in me.
How many have tried a simpler 'hardware store' solution to this issue?
I am about to go down to my local Ace Hardware or Home Despot and try something with my three favorite adjectives: Simpler, Cheaper, and Reliable.
I will post my results when I have something to report...
Andy
Posted: Aug 16, 2024 2:18 PM
MisterFixit wrote: Aug 16, 2024 2:04 PM
Andy
Looking forward to this "cheaper" solution.
Posted: Aug 16, 2024 4:06 PM
by stuartinmn
If a person wanted to go with something really basic, 1960s Ford pickups (and probably many other vehicles) used a manual valve that was operated with a cable, so water flow to the heater core was basically on or off. They sell for around $30.
Posted: Aug 16, 2024 4:26 PM
Andy
I was ready to dismiss your suggestion out of hand, thinking a mechanical valve, no problem. An electric valve, well that's another story. So I searched for a 12V water valve and up come some things, not that expensive. Plastic ones really cheap, but I don't think those would work for long, but even brass ones aren't that expensive, like 1/2" for twenty bucks. Or a Viton one for $30. However, duty cycle may be a problem. And solenoids have a big inrush on current, but little on hold, but if it cycles a lot that could generate a lot of heat. They even say max 8 hours duty cycle though I don't know if that's continuous or what. They all seem to be normally closed so a relay to reverse polarity would be required, and maybe even only use the factory power to switch the relay rather than risk burning out the driver for it. So again, depending on duty cycle, it might only last 3 days. But nothing ventured nothing gained.
Of course you could use a plain mechanical valve as came on late E21s and either set up a Bowden cable or just manually actuate it by season, but the latter is kind of declass for a BMW.
Posted: Aug 16, 2024 4:34 PM
by MisterFixit
1st 5er wrote: Aug 16, 2024 2:18 PM
Andy
First report- parts in hand, total cost $21.89... CHEAPER
Posted: Aug 16, 2024 4:49 PM
by MisterFixit
stuartinmn wrote: Aug 16, 2024 4:06 PM
We are on the same wavelength, Stuart. I was thinking of my 2002 cable operated valve.
Posted: Aug 16, 2024 5:01 PM
by MisterFixit
Mike W. wrote: Aug 16, 2024 4:26 PM
Andy
Yeah, the BMW operating model is kind of 'jittery' with lots of cycling. Anything designed for 'occasional' on/off is not likely to survive. I am using the mechanical solution, and since I adjusted my hood latch mechanism to actually OPEN THE HOOD with a tug, which it wasn't before, the 'per season' adjustment will work for me. Hell, I do check my oil more often, so
no hay problema!
The last time the hood was removed/replaced for major engine work, it was misaligned and WOW, what a PIA it was to open and close! AFTER I finally got it open, I did some backyard bodywork, adjusting and bending things until it worked properly. THANK YOU, MyE28 Tech FAQ, for the instructions on how to open a cranky hood. (We Rock!)
Posted: Aug 18, 2024 2:36 PM
by MisterFixit
UPDATE-
I pulled a used valve from a parts yard yesterday -- not very often you find an '86 E28 in the yard!
My intent was to find the exact diameter of the input and output fittings; no manufacturers of replacement valves will tell you this, just how to buy one of their valves!
I measured them to be 0.7804 inches (+/-), so I plan to try a 3/4 inch hose barb fitting.
Posted: Aug 18, 2024 5:07 PM
I'm still not sure about duty ratings, but if one could find a budget steam rated valve it might work well, steam is hot, really hot, so even the coil for the steam rated valve might be rated at enough heat to take a higher duty cycle. Might not, but might.
Posted: Aug 18, 2024 8:45 PM
by K-jetFTW
I've been running a Four Seasons 74678 ball valve since 2019. Similar to Stuart above pic. It's fine.
I never cared enough, but I'm sure there's a universal carb cable kit that can be modified to work from inside. Lawn mower throttle cable maybe.
Posted: Aug 19, 2024 11:47 AM
by MisterFixit
Refreshing, but not surprising, to see so many ideas popping up!
Posted: Aug 19, 2024 6:11 PM
by DavidE9
If any of you really need one, I have a spare I can send you. The housing isn't in good shape and probably can't be saved but the value inside still responds to voltage. Yours for free if you really need one and aren't just taking it because its free.
Posted: Aug 19, 2024 9:54 PM
by Ohmess
Obviously a different type of valve, but perhaps the process The Hack Mechanic used for the e9 might be helpful:
https://e9coupe.com/forum/threads/diy-h ... ost-128141
Posted: Aug 19, 2024 10:20 PM
Didn't read the full E9 link, but I wonder if how a vacuum actuated valve would hold up. I believe vacuum switching valves are inexpensive so one might be able to use a vacuum switching valve to control vacuum to the valve much like the original design. I don't know again about duty cycle, just how many hundred or thousands of cycles they are capable of, but it might be worth investigating. I know lots of cars, including on BMW at least E23s used a vacuum water valve.
Posted: Aug 22, 2024 12:38 PM
by four2zerohero
for my e23, I have contemplated using a Mercedes heater valve out of a w201, they are vacuum operated and cost 17 bucks, better than replacing or rebuilding the behr one, Mounting wont be as nice as the original, but a possible solution.
Posted: Aug 22, 2024 12:52 PM
by MisterFixit
OK, parts in hand, getting ready to install. I'd post a picture of my workaround, but it seems my cable for this is AWOL.
No, I do not own a smartphone, and the camera is not 'wireless.' It is digital, but needs an umbilical to download images. I'll keep looking... Help me, Saint Anthony.
Posted: Aug 22, 2024 4:14 PM
MisterFixit wrote: Aug 22, 2024 12:52 PM
And I thought I was behind the curve on smartphones.
Really, if you don't want to go that route it might still be worth it to get one, not to use as a phone, but for pics. Then you could just email them to yourself if you have WIFI. Without phone service. Used phones are so cheap if you get an old one and some have pretty decent cameras even if the manufacturers try to obsolete them in various ways. Might want to think about it.
Posted: Aug 26, 2024 7:38 PM
by K-jetFTW
For a BMW-correct solution, one could convert to E28 manual water valve 64211368650.
You would use manual temp dial 64111373938 with bowden cable 64111367698, or use another similar cable from the yard.
Guessing this would not only be more reliable, but also still cheaper than the $400 new water valve. Better appearance. Loads of 518's probably came this way overseas.
Wondering if anybody done this ? Maybe a Euro member ?
Posted: Aug 26, 2024 8:06 PM
That looks very similar to a US market late E21 valve. I've even got one or two of them in my box of water parts.
