G260/6 from 87 535is Can broken mount tab be replaced, welded?
Mab1957
Post by Mab1957 »
The passenger side transmission mount tab of Getrag 260/6 in '87 535is was broken and is missing. Can the tab or mount part of the casing be replaced or welded?
Re: G260/6 from 87 535is Can broken mount tab be replaced, welded?
Yes.
Had it happen on son's E30 years ago.
Mab1957
Post by Mab1957 »
Did you weld something on to serve as the tab, or replace that part of the case?
Thanks CEK for this photo. Image
