Hi All.
Might any of you knowledgeable folks have a workaround/fix for the fuel sender unit? I can confirm the problem lies with the sender unit. Shorting the pins onbthe cable going to the sender unit gives me fully empty and fully full.
I looked inside the sender unit. Hopefully I didn't break it. I don't recall seeing the two small wires extending through the full length of the internals. I'll double check this today though.
The obvious thing is to simply replace with a new unit, but these are not cheap. In EU they're 300 euros or so, and inbthe states, they're cheaper, but then I have the taxes and delivery costs , bringing up the proce again.
If there's a repair I'm then I'd love to try that, or if any of you have a confirmed good second hand one then I could maybe go for that.
Thanks in advance.
On a side note, I have resurrected my M535i after 18 years of storage and ownership. All the correct re-torqueing and re-lubing, and lots of other things have been done. She starts and drives as it should - and it's great fun!!!!
M535i (B34) In-Tank Fuel Sender Unit
Re: M535i (B34) In-Tank Fuel Sender Unit
Also, to point out, this sender unit literally worked only days ago!! I took it out to replace the in-tank pump. Hasn't worked since.
Congrats on the resurrection! I have no info on how to repair the sending unit, but I did replace mine with a cheap copy (herko unit) and it's been working fine for over a year. Might be a little hard to find now but they should be around 60-80 euros, a cheaper option if you want to go that route.
Quite a simple fix to rewire it with Cr20Ni80 0.08mm wire. Just needs soldering, nothing clever. Available on ebay for a few Euros.
