Clear Oil Service indicator
topher800
Post by topher800 »
Since the search results are not yet available, can someone refresh me on resetting the oil service indicator. I believe there was a paper clip option between two of the OBDC holes.....
topher800
Re: Clear Oil Service indicator
Post by topher800 »
Got it. Pins 1 & 7. Used an RCA cable. Pin 1 is in the center. And pin 7, looking north from the flat edge, is at 1 o'clock (first hole).
Connect wire, turn key to run, without starting. "For the inspection light, hold the key there for 7 seconds - 11 seconds for the oil service light".
topher800
Post by topher800 »
Looking for a cover. Why does it look like 12521724690 is for the 20 pin port?
