This'll leave a mark...
I figured I'd just install the engine upside down anyway so the bores and backs of the pistons fill with oil
I aimed the squirters at the center of the wrist pin when at TDC... 20 degrees from vertical. I feel there will be sufficient coverage that way.
<img src=http://groups.msn.com/_Secure/0RgDdAuUT ... 4506138562>
My previous smartass post aside, I've often wondered how much engineering and how much "lets just point 'em up the bore" there was back when BMW first put them in. Spraying a constant stream up there at a fast moving target probably results in a goodly spattering of oil all over the piston. As long as it doesn't get too much on the bore I would think the exact angle isn't critical. But then I'm not a German engineer.
First I have to get 5 more drills since I left the first one in the hole.dcbrewmeister wrote:Question - How are you going to get all 6 cyl?
Seven main bearing seats, I drilled/counter bored 6.
BTW, the drill that I left there so that I could go to lunch... it's held in place by the Bridgeport which the block is sitting upon.
I, of course, contemplated the angle. At first i thought to aim them at the center of the wristpin when at half stroke but assumed that, at TDC, the spray would hit the far side of the bore.... but then, it may not... it would nicely hose down the rod... hmmmm. Then, I thought, what does the spray pattern look like... the angle of the cone, etc. I stuck one of the nozzles in a short length of 1/4" fuel line and filled the line with 15-40 oil I had warmed to about 150F. I adjusted my compressor to 45psi, placed the blowgun in the other end of the fuel line and sprayed the oil onto a piece of cardboard from 5 inches (roughly the distance from the installed nozzle to the centerline of the wristpin). This produced a circular pattern of about 2" Dia.... nice for covering the bottom of the piston while at TDC.
Now that is the kind of quality information I come here for.I stuck one of the nozzles in a short length of 1/4" fuel line and filled the line with 15-40 oil I had warmed to about 150F. I adjusted my compressor to 45psi, placed the blowgun in the other end of the fuel line and sprayed the oil onto a piece of cardboard from 5 inches (roughly the distance from the installed nozzle to the centerline of the wristpin). This produced a circular pattern of about 2" Dia.... nice for covering the bottom of the piston while at TDC.
That's the best idea I've heard this week. That should take care of any problems with cam oiling too.Sweeney wrote:I figured I'd just install the engine upside down anyway so the bores and backs of the pistons fill with oil![]()
The M106 block is drilled a little off center, maybe to aim around the rod at TDC? Still I think your positioning will work fine. I just stuck a dowel in the hole to see where the nozzle was aimed, like you say it appears the goal is a good pattern at TDC.
Hey Shawn,
I was thnking about a jig also in case anyone (without a Bridgeport or the like) wanted to do this. I would do as you mentioned, utilize the bearing cap mounts. An aluminum block with steel guides, solid steel or a steel construction would work.
I used a 3/8 end mill (because I dropped and damaged my last 5/16 mill) for the counter bore, spot drilled the center and then through bored with a 6mm drill. With a jig, I'd drill then use a piloted counter bore or a combo drill/counterbore.
The nozzles drop right in with the flange just below the level of the bearing seat. I plan to use GM gasket maker to hold them (though they are trapped by the bearing) and seal around them.
Me 2. Nice job Sweeney.DMNaskale wrote:Now that is the kind of quality information I come here for.I stuck one of the nozzles in a short length of 1/4" fuel line and filled the line with 15-40 oil I had warmed to about 150F. I adjusted my compressor to 45psi, placed the blowgun in the other end of the fuel line and sprayed the oil onto a piece of cardboard from 5 inches (roughly the distance from the installed nozzle to the centerline of the wristpin). This produced a circular pattern of about 2" Dia.... nice for covering the bottom of the piston while at TDC.
RussC
Yer thinkin' wrong, mister........louielouie wrote:How will this affect overall oil pressure having 6 more points of pressure loss? I'm thinking oil pressure at low rpm's will be noticably lower...
These nozzles have ball check valves built in. If I recall, the cracking pressure is 40ish psi. They won't spray until sufficient pressure is present.
Not just turbo engines have them, for instance, E46 M3 as well as others.
Yes, for cooling pistons and also for improving oil volume delivered to the oil rings and wrist pins. Without the nozzles there is only random splash oiling primarily from oil coming of the rod bearings. Some engines actually have notches in the sides of the rods at the bearing seat to allow more oil to be flung upwards towards the piston.
