Turn signals don't work, but hazards do! What gives?
General E28 FAQs.
Locked
Tjn182
Post by Tjn182 »
PROBLEM My turn signals don't work, but my hazards do! What gives?
CAUSE 1) Busted signal switch (lever) - worn out and in need of replacement, or 2) Fuse 11 is bad.
SOLUTION 1) Order a new turn signal lever (make sure you specifiy if you have the ability to switch ECU functions via the lever). It's a simple removal of the steering column, unscrew old part, screw in new part; or, 2) Check and/or replace Fuse 11.
If neither your turn signals nor your hazards work - then your problem is with the turn signal relay - a universal part, located in the steering column as well.
Locked
