Suprisingly enough they actully feel better for comfort than my Old 16"s , Im quite shocked..as i expected it to be Horrid.
But my car is exremly stiff Suspension wise..ie: you can not even push it down from the bonnet barely.) Prehpas thats why the ill effects of large wheels is probably less noticable..but whats wierd it seems to ride the bumps better?
But it is Letting a bit loose on the rear in corners...im not sure of the Crap Second hand tyre si have on the rear...or The wheel size...I was think the Wheel size has effected Self Alighning torque...The abilty for the wheels to turn back byu them selves to straight forward.
This may be the case...as it feels like it is not coming back as fast as it used to...and if it is doing that coming out of the corner there is more Latreal force against the rear tyres making them slip.
The First photo is done with the flash:
The second with out flash
THis is a Pci with a 50cent coin on the Lip..it is out biggest coin here..BIG LIP.
There was no Mods done to fit these..they where perfect. My car is lowered BTW..and really the whole circumfrence was the same as the old 16's with the 35 tyres..compard to 55's
