Which tranny is this?
skip535i
Post by skip535i »
I have this tranny out of my old car (was a replacement from a 533i I belive).
It's in my garage and needs to go so I'm gonna sell it dirty cheap.
It was a great tranny, nice a tight when removed.
Looks like a Getrag 260/5 to me, especially if out of a 533i...
steve 87 535is
Post by steve 87 535is »
Same here, because the bellhouse isn't removable (so not a 265), the shift plate mounts look like sheet metal ones and the cooling fins on the bottom are smaller( so not a 260/6).
That's a 260/5. It should actually say that on I think the left side of the case.
kvashay
533 transmission
Post by kvashay »
The transmission is a five speed , correct? Can you tell me if the production date was pre or post jan 1984
Re: 533 transmission
kvashay wrote:The transmission is a five speed , correct? Can you tell me if the production date was pre or post jan 1984
Why does that matter? The flywheel isn't part of the transmission.
spinedocab
Post by spinedocab »
It may matter because the 260/5 requires the proper pressure plate to fit inside it's smaller bellhousing. The chunkier clutch bits won't go in there.
AB.
AB.
But, we know it's a 260/5 and since they were used only in '83 and '84, then then the 265, followed by the 260/6.
