Under engine tray?
Posted: Jul 16, 2008 2:22 AM
by djazz
I've searched but lack the correct term I suppose.
Does anyone have the correct name and/or part number for the under engine aerodymanic tray. Not talking about the aggregate protection plate, aka skid plate.
Mucho appreciated,
dj
Posted: Jul 16, 2008 2:47 AM
Posted: Jul 16, 2008 4:33 AM
by djazz
So is it #6, or 6&7? Engine Compartment Screening could apply to both.
Posted: Jul 16, 2008 4:50 AM
by ElGuappo
Do you have the M-Tech kit? I think its part of that...
Paging JBort, please pick up the white courtesy phone...
Jay3
Posted: Jul 16, 2008 4:53 AM
djazz wrote:So is it #6, or 6&7? Engine Compartment Screening could apply to both.
#6 is the one that most refer to as the under tray.
Posted: Jul 16, 2008 5:25 AM
by djazz
No just a 535i, and I don't really want the full M-tech look. I may go euro bumpers later but I'd like a true Q-ship look so I'm checking out less obvious ways to improve stability.
Could this work on it's own? With US and/or euro valance?
Any more info would be great.
Thanks,
dj
Posted: Jul 16, 2008 5:30 AM
djazz wrote:No just a 535i, and I don't really want the full M-tech look. I may go euro bumpers later but I'd like a true Q-ship look so I'm checking out less obvious ways to improve stability.
Thanks,
dj
It will go in no trouble. If you look at the underside of your frame rails, the mounting points are there. You'll see the flimsy-ass point up front where one unnamed company thought you could bolt a chassis-stiffening brace. Obviously BMW thought it was good for little more than some plastic (though that is a mounting point for the aggregate protection plate). It connects there and then further back on the frame rail. The only differences in US/Euro valances are the cutouts for turns/fogs.
In fact, pdx528e's old '83 had one of those fitted when new. I imagine it's incredibly useful in Portland since every time I hit little more than a smattering of water, the belts would squeal then I'd lose power steering - once while making a u-turn.
Just a 535i? How often do you think that was uttered in the 1980s? That's top of the line, baby...until 1987.
Posted: Jul 16, 2008 7:43 AM
by a
If you find one , make sure it comes with a door below the oilpan plug. Or it will have to be R+Red for every oil change. According to Ted from TO , it is a worth while accessory . It provides noticeable down force at speed.
Posted: Jul 16, 2008 8:34 AM
by Tusker
FYI HERE is a realoem listing for my car with 6 & 7 listed.
I can't speak for it's efficacy at speed as it was factory fitted.
Posted: Jul 16, 2008 8:35 AM
by stuartinmn
The undertray in my M535i looks more like #6 than #7 in that diagram, but the cutout in the bottom is shaped so it fits fairly closely to the oilpan. I have to take it off to do oil changes. Also, the front edge fastens to the rear edge of the M-tech bumper cover.
I think I have a photo of it on my computer at home, I'll try to post a picture tonight.
Posted: Jul 16, 2008 11:55 PM
by djazz
Many thanks everyone.
Anyone know if it is #6 & #7, or one or the other? I'm asking because I can see where #6 would go to the M-Tech kit, but #7 looks like it would match up to a valance.
Pics would be great. And I'd love to see one with a door for the drainplug.
dj
Posted: Jul 17, 2008 10:58 PM
by stuartinmn
I almost forgot about this thread...here's a not-so-good photo of the undertray on my M535i. I thought I had a better one but this is the only one I can find at the moment.
Note how the cutout is shaped around the oil pan.
Posted: Jul 18, 2008 1:48 PM
by Rich Euro M5
djazz wrote:Many thanks everyone.
dj
DJ,
You want Item #7. This part is used on the Euro M5 without the M-Tech kit and bolts up to the standard front valance.
Rich
Posted: Jul 18, 2008 3:49 PM
by Bill in MN
Stuart, what's the chance of using your tray as a pattern sometime this winter?
Posted: Jul 18, 2008 6:19 PM
by Crazy_Canuck
My 518 has #6 in the diagram.
Like others have said, you want #7 for a 535i
Posted: Jul 18, 2008 7:13 PM
by stuartinmn
I knew I had some more pictures...here are top and bottom views of the M535i undertray off the car.
Posted: Jul 18, 2008 9:10 PM
by a
If you plan to clone one.,a 2'' hole cut into it under the oil drain plug and a KO plug would solve the PITA oil drain. In a fit of drunken bravado , I volunteered to do an oil change on Ted Kalman's M 535i . Between the tray and the old school basket oil filter :roll:
Posted: Jul 18, 2008 10:42 PM
by stuartinmn
a wrote:If you plan to clone one.,a 2'' hole cut into it under the oil drain plug and a KO plug would solve the PITA oil drain. In a fit of drunken bravado , I volunteered to do an oil change on Ted Kalman's M 535i . Between the tray and the old school basket oil filter :roll:
That's why eventually I want to come up with some sort of quick release mount for the thing, with Dzus fasteners or something. I have gotten pretty good at R&Ring the thing, I can even change oil without jacking the car up (I do have long arms.) :D
Posted: May 30, 2009 12:31 PM
by cgraff
FYI,
Here's the "full undertray" used on the Euro M5 (and other big-six engined E28s). It will not fit on the M535i or cars with the M-tech front spoiler.
What's nice about this one is that it covers up the wheel wells, and goes all the way forward to the edge of the valance. It's a very nice piece.
PN: 51 47 1 929 114
http://www.m535i.org/officers/cg/cgpics ... ertray.jpg
-Chris
Re: Under engine tray?
Posted: Feb 17, 2019 6:33 AM
by robertodonnell
Hey guys,
Just been digging through and came up with this thread. Can anyone confirm which tray is the one compatible with the M535i, with MTech bumpers? realoem lists 3 P/N, one being for aircon cars.
http://www.realoem.com/bmw/enUS/showpar ... Id=51_1830
I have an aircon M535i MTech car, UK spec, so I want the correct tray for it.
Cheers,
Robert
Posted: Feb 17, 2019 8:17 AM
by Sagi
M535=pn 51471929927
Just got it from Germany.
Number 7 on this diagram but it looks different then the diagram.https://www.leebmann24.de/bmw-ersatztei ... bt=51_1830
Re:
Posted: Feb 17, 2019 8:19 AM
by Sagi
stuartinmn wrote:I knew I had some more pictures...here are top and bottom views of the M535i undertray off the car.
Posted: Feb 20, 2019 6:33 PM
by jca
Very cool part...
Re:
Posted: Feb 20, 2019 7:33 PM
by ElGuappo
I was fortunate to receive this part with my latest 528i acquisition, even though its been damaged and modified at some point.
Should still be cool to figure out a way to mount it and enjoy all the aero tray goodness.
