Chassis - 1988 528e, 52K miles, single owner, full documentation, sat in garage in Orange County from 92 on. Last time it was registered was 93. EVERYTHING works and is in great shape, no paint chips, no cracks in windshield, no sun fad, perfect dash - The guy I bought it from was really glad that a true BMW enthusiast was buying, he was very happy - I am sure he did not understand what I was going to do with it! This is the nicest used car I have ever bought - it is like going back in time.
What it needs - carpet; since it sat for so long, mice made it a home, so it stinks like urine - YUCK - I will replace the carpet this winter. I have a set of manual sport seats that I will recover in a proper euro style fabric with matching rear bench and door cards, I still need to install the manual pedal cluster and shift linkage
Engine (complete) - S52 - displaces 3.3L w/ 8.5 to 1 turbo pistons, ARP head, main and rod fastners, Eagle rods, balanced. Rebuilt head with fresh valve job, MLS head gasket, M50 intake, fresh timing components - chain, sprockets and rails, rebuilt oil pump, e34 M50 sump, euro filter housing with oil cooler fittings.
Transmission - e36 M3 ZF 5 speed, 2.93 LSD, light weight aluminum fly wheel and 400 hp clutch, fresh slave and master cylinder
Exhaust (60% complete)- TCD cast turbo manifold, true T04e-60 turbo able to support 500 hp, update 5/09 single 3" pipe to the rear, will use a 3 " down pipe, external 38mm wastegate (TIAL)
Intake/Fuel (60% complete)- M50 intake manifold, intercooler still pending (very tight for an air to air), might do H2O to air, 42lb injectors
Engine Control - I am leaning towards the AEM setup on Evosport.com website - it is PnP for the s52 engine harness. http://www.evosport.com/product/aem/
Motor/Transmission mounts (complete) - e36 motor mount arm (drivers), e36 turbo motor mount arm (passenger), Toyota Supra polymounts - ( the e12 motor mount setup was way too soft), e34 M50 manual transmission crossmember (puts engine/tranny at the correct angle - took a while to find the right combo via the ETK), e12 poly tranmission mounts
Front cross member mods (complete) - remove the worm & roller box mounts, idler arm mount (in the way of the turbo), steering stop arms (little things on the subframe), add needed material to raise motor mount locations by 2" (I used 2" square tube welded to the subframe), make features to support steering gear - in process
Suspension (90% complete)- Ground Control coil over setup front and back, with Koni SA shocks/inserts, cut down front strut housings to put shocks in ideal travel location, GB camber plates, e31 840i aluminum control arms with spherical bushings, e34 M5 spherical trailing arm bushings ($), e32 750i front thurst arms, fully machined poly subframe bushings, poly filed diff bushings, strut bottom spacers (get the roll center where it needs to be after lowering - allowing good camber gain), Ireland Engineering camber and caster adjustments for the rear subframe, Koni sway bars with spherical drop links and poly mounts - no rubber anywhere, it will be rough, but I want a very good handling 5 series.
Steering -(90% complete) - originally - power rack and pinon from an e39 528i 3.25 turns lock to lock - THIS DOES NOT WORK!!!!!!!!! I am a ding dong - the e39 cars are front steer cars - I had this 90% done and realized my bone head move. Back the drawing board.
Update - 2/09 - found a rear steer rack at www.Unisteer.com. This is a power unit with 2.8 turns lock to lock, roughly a 13.5 to 1 ratio - so pretty quick. Brand new - $300 delivered. I will need to run a pressure reducer circuit in the PS setup - the BMW bump puts out more PSI than the rack needs. I found one on a local hotrod web site.
Had to have the inner tie rods shortened and new M14 threads cut to work with the e28 outer tie rod ends. I found an e36 u-joint that allowed the BMW splined steering shaft to mate up with the double D shaft and splined end of the rack. I tied the front subframe and rear lower brace together to provide a location for the rack to sit. Worked hard to assure the rack was at the right height, so that steering arms and control arms where parallel to avoid bumpsteer. Had to move the location the steering shaft exited the firewall - used a firewall steering shaft bearing to seal it up.
Brakes - (complete) e34 540i calipers front and rear - powder coated black with new clips and pads, Zimmerman cross drilled rotors, e32 750i master cylinder, new SS flex lines
Exterior - (purchased, but not installed) full euro, had the bumpers rechromed, big/small head lights, proper euro valance and factory front spoiler. I found a real nice euro e28 under tray on the ETK - that goes from the valance to the subframe - you can see that in one of the images...
Wheels - factory e39 540i sport wheels 8x17 and 9x17 with 235 and 255 tires
I want this car to be a sleeper. No spoilers, stripes, wings, in fact I have a set of 16" factory steel wheels which I will have widened to 8" and will run BMW hub caps and beauty rings. I want to see the face of the Porsche GT3 or new M3 driver when the old euro taxi goes flying by at DE school.
I think it should be running by December08 - Update 5/09 - maybe end of the summer 09?
