I've been here a while and there's one particular formatting issue which I find bothersome. I hope and pray that I am not alone. I feel could be resolved easily and without pain.
The problem surrounds the "Cool" emoticon. It's code is as follows:
Code: Select all
8)
With this being a rather technical message board, what with numbers and all in occasional use, It becomes a problem if you want to use numbers such as 8 in parenthesis like this:8)
Code: Select all
(3.8L V8)
I think it would be a smashing idea if the code for the "Cool" emoticon was changed to something like this:(3.8L V8)
Code: Select all
:cool:
Thank you for your time! I appreciate all of the great work you folks do!
Regards,
Christopher Kohler
