Will not let me change my email
Zach716
Post by Zach716 »
when i go to change my email address and click "submit" it says "the current password does not match what is stored in our database" but i didnt change it. so... if one of you guys could kindly change my email to zachcarpenter3@yahoo.com that would be awesome. thanks!
You must confirm your current password if you wish to change it or alter your e-mail address
You have to enter your current password into the proper field in order to change your e-mail address. Then you will have to re-activate your account via the activation link that will be sent to the e-mail address you provided.
misha
Re: Will not let me change my email
Post by misha »
Zach716 wrote:when i go to change my email address and click "submit" it says "the current password does not match what is stored in our database" but i didnt change it. so... if one of you guys could kindly change my email to zachcarpenter3@yahoo.com that would be awesome. thanks!
I have the same problem. I know that the password that I type in is correct, but it never takes. Can one of the beamters help us out with this problem.
Justin_FL
MyE28 IT Guru
MyE28 IT Guru
Post by Justin_FL »
Make sure you only put your current password once, in the field below the email address. Leave the last two blank, as those are only for changing the account password. I suspect this might be the problem.
Also make sure you input a correct email address as you will otherwise be locked out of your account by supplying an invalid one.
Zach716
Post by Zach716 »
fixed, thanks for the quick response, NOT!
