Last week my son tried to unlock an already unlocked door on the 735i, and ended up deadbolting the thing. Usually not a problem, as it's an easy enough matter to open the door if you know the right moves with the key. Trouble is, that the driver's door lock has been a little on the sticky side since I bought it, and we've had a string of days with sub-zero temps, and now the driver's door just won't unlock. Everything else unlocks just as it ought to, but not the driver's door. I've found plenty of help on how to clean up or replace a sticky lock mechanism, but that usually involves pulling the door card off an open door; since the door is locked, I can't open the $&#(^%& thing to get the door card off!
So far I've tried applying heat to the outside of the door, and running the heat inside, hoping to warm up the mechanism in the door enough that things will move again, but no joy there. I've also tried pulling the door card off with the door closed, but the door card and the trim around the door is all in perfect shape, and I really don't want to wreck any of it. I did get a the top corner near the back of the door pulled back, but could only see the lock button rod and the cable/wire connecting the inside door handle to the lock mechanism; I'd have to get pretty far down with that to be able to get at the parts I need to get it open. I called a locksmith, and he wouldn't even look at it; said that he tried to get into a deadbolted BMW once before, and they ended up breaking a window to do it. The Bentley also mentions the possibility of the lock mechanisms being out of sync, but I've gone through the synchronization process a half-dozen times, and the driver's door is still stuck. You can hear the actuator thunking inside the door, so I'm thinking that something is jammed or just plain too sticky to move.
I think my last resort with this thing is to take a utility knife to the padded inset above the armrest and cut myself an access hole to get at the mechanism. I really hate to cut into it, but it seems this is the only reasonable way to get inside the door. The padded inset area seems like the perfect place to do it because it appears to be in the right place to reach the actuator and lock mechanism, plus that part of the door card would be the least trouble to repair.
So, have any of you e32 veterans or BMW techs have any experience with this sort of thing? I'm getting really tired of climbing over the console to get in & out of the thing! (And it's too blasted cold for a General Lee ingress/egress method!)
