OPERATION TIGER'S TEETH -**Boltin on MO Power**
Just a tease for the future - blueprinted, 347 cubic inch, roller cam.........
Can you say..............400 HP conservatively?
More to follow................................ :banana:
Snakeyestx
Post by Snakeyestx »
A Tiger with a street-fighter? That oughta be a wild ride :laugh:
Philo
Post by Philo »
400hp and the car weighs 2400 lbs aprox... ? Now that's going to be a fun ride !
Philo wrote:400hp and the car weighs 2400 lbs aprox... ? Now that's going to be a fun ride !
Yup....thats the point.
Dana R
Post by Dana R »
I think you should put in an m20 eta engine in the Tiger! April Fools!
A pushrod V8. :zzz:
More info -
1991 5.0 HO block
Scat 9000 Crank
Probe I beam rods (5.315)
Probe SRS pistons flat top
Clevite bearings
1/2" girdle with windage tray
Trick Flow Stage 2 Hydraulic Roller Cam
(Specs Duration at .050 Int - 224 Exh – 232 with Intake lift at .542 and exhaust at .563 with a 1.6 rocker, 112 overlap)
Soco
Post by Soco »
i mean thats cool, but we have a 350 in the garage (in a bmw chassis too) without a roller cam or blueprints, and yet the procharger blower we have in it will net us 600 hp conservatively.
Really in the end, forced induction always wins. Now if you were to twin turbo it, then it would be scary and cooler.
Soco wrote:Really in the end, forced induction always wins. Now if you were to twin turbo it, then it would be scary and cooler.
This guy has and is running 9.55 quarters.
http://teae.org/forum/viewtopic.php?f=2 ... 7423#p7423
Mike W. wrote:A pushrod V8. :zzz:
Oh come on, get yer nose outta the air. What's the Corvette Z06 have? Pushrod V8. ;)
I thought of you the other day, Duke... The Hemmings Sports & Exotics magazine I was reading had an ad in it for a company that drops a Chevy LS3 & a 6-speed in a Miata, and they bill it as the modern-day Sunbeam Tiger. They need to come up with a name though; Miata just doesn't do it for a roadster with that kind of HP!
:haul:
Just got another piece for the project. A scatter shield. A little heavier than the aluminum bellhousing but well worth the weight in safety. It will also allow the easy bolting of my narrow pattern toploader to the 1991 6 bolt HO block.
frink84
Post by frink84 »
looks like a fun mill for the tiger!
Post by Coldswede »
ETA for launch of the toothy Tiger?
Coldswede wrote:Duke
Spring next year. Lots to do and acquire before then.
w0014170
Post by w0014170 »
Fastest Duke in the West :banana: Might last 5 secs in the quarter mile :banana:
Bimmerguy2002
Post by Bimmerguy2002 »
i have a m5 flywheel for sale if interested duke, to make use of that scatter shield, its a direct bolt on to the tiger.
Patrick McHugh
Post by Patrick McHugh »
w0014170 wrote:Fastest Duke in the West :banana: Might last 5 secs in the quarter mile :banana:
Lols
Bimmerguy2002 wrote:i have a m5 flywheel for sale if interested duke, to make use of that scatter shield, its a direct bolt on to the tiger.
Your M5 flywheel would not last 5 minutes in the Tiger :cool:
Is this the same as (or different) a crank scraper? What additional HP should it be good for between what rpm ranges?
Nebraska_e28 wrote:Is this the same as (or different) a crank scraper? What additional HP should it be good for between what rpm ranges?
http://i796.photobucket.com/albums/yy24 ... /002-1.jpg
Its a windage tray. Different than a crank scraper.
"When the crankshaft is rotating say at highway speed a horizontal vortex of swirling air is generated. The oil in the engine that was pumped up high and residual from the crank assembly is draining back to the oil pan gets caught in this vortex and is spinning too. Some estimate that anywhere from 1 to 3 quarts of oil can be caught in this vortex. A wind-age tray acts like a scraper and removes the oil from the vortex letting it drain back to the oil pan. It does not actually touch the crank shaft but it is close enough to it to skim off the oil and let it drain."
I had a Hartge windage tray in my NA motor.
Update - Plans for Winter 10/11
Now that the big show is over and my car is running perfect, time to get back to the 347.
I just received a rear spring re-enforcement kit that I will be welding in this winter. The front mount points of the leaf springs can actually separate from the body/frame with a high HP engine. A relatively simple fix to prevent this is to weld in three plates on each side. It is much better explained here - http://www.tigerengineering.net/TECHTIP ... cement.pdf Because my car has none of this stress damage, its a perfect time to install the kit.
No - this mod does not devalue the car one $.
I am also installing 1985 RX7 rear disk brakes this winter. A complete bolt on mod. I will also modify the front calipers so they will work with vented rotors.
The final winter mod is to remove all of the interior and fix any surface rust, paint with POR 19 chassis black and then cover the tub with Thermo Tec heat and noise shielding. I was waiting to do this once the car had been authenticated.
In the spring the engine will get completed.
Duke wrote:Update - Plans for Winter 10/11
In the spring you will need to buy this suit to keep cool once that big piece of U.S. iron is installed in your car.
HA!
And do not get me going about RX7 brakes, HA!
chrism
Post by chrism »
:blah:
Mark in Toronto wrote:In the spring you will need to buy this suit to keep cool once that big piece of U.S. iron is installed in your car.
How about one of these? -
Mark 88/M5 Houston
Post by Mark 88/M5 Houston »
You might consider this product for your insulation, both sound and heat, needs. It seems to be the latest and greatest thing going for this in the hot rod world right now.
http://www.lizardskin.com/lizard_skin/street_rods.php
Cool....er
Mark 88/M5 Houston wrote:You might consider this product for your insulation, both sound and heat, needs. It seems to be the latest and greatest thing going for this in the hot rod world right now.
Thanks Mark but........that looks like a real PITA to remove. I always think "what would it take to return the car to a 100% factory original car?". Thats why I only do bolt-on/reversible mods. Frame re-enforcement aside.
RossDinan6
Post by RossDinan6 »
It will be interesting watching this thing implode like the BMW.
Ross
L_N_Love
Post by L_N_Love »
RossDinan6 wrote:It will be interesting watching this thing implode like the BMW.
Ross
:popcorn:
I'm waiting for operation Tiger Penis wherein the car gets bought by the Chinese, ground into powder, and sold as an aphrodisiac.
