Page 1 of 3
Valve Cover Candy - Redux page 2
Posted: May 06, 2010 3:54 AM
by Das_Prachtstrasse
Figured i'd do something with the valve cover that came on the m106 before dropping the motor in the car, and so i went to town with some VHT wrinkle paint, some sand paper, and an oven.
Here's the result.
Before:
After:
Before sanding
After sanding
I'm so pleased with the results, i'm going to have a crack at the intake plenum next. Slight improvement over stock don't you think?
Posted: May 06, 2010 4:06 AM
by Dinan e28
That does look good. Nice work.
Posted: May 06, 2010 10:31 AM
by Coldswede
Nice! Good job!
Is she speaking to you yet after stinking up her oven? ;) :laugh:
Posted: May 06, 2010 11:46 AM
by Brad D.
Tasty!
Posted: May 06, 2010 1:48 PM
by Jake D
MMmmmmmm!!! :alright:
Posted: May 06, 2010 4:40 PM
by genzox
nice cap :up: I just painted mine last week i'll see if I can post some pictures
Posted: May 06, 2010 5:48 PM
by genzox
Posted: May 06, 2010 9:59 PM
Coldswede wrote:Nice! Good job!
Thankfully at the moment there isn't a 'she' to complain! That's the beauty about living in a bachelor pad :laugh:
Posted: May 06, 2010 10:53 PM
by PROJECT. E28
oh god, its orange
Posted: May 06, 2010 11:28 PM
by Scottinva
Is it painted, or powder coated? I don't get this oven talk.
Posted: May 07, 2010 12:08 AM
Scottinva wrote:Is it painted, or powder coated? I don't get this oven talk.
Painted with a high temp wrinkle finish paint from a spray can, and cured/set in an oven. This type of paint requires heat to wrinkle and cure, hence the oven speak
Posted: May 07, 2010 12:45 AM
by Scottinva
Oh what temp, and for how long did you put it in the oven?
Posted: May 07, 2010 1:09 AM
Scottinva wrote:Oh what temp, and for how long did you put it in the oven?
Here's the procedure i followed in step form for those interested, including yourself.
1. Seeing as it was already semi-polished and absent of most of the original coating, i simply degreased it, sanded it with 60/200/400/600grit wet dry in stages till the surface was relatively smooth, washed it with water, dried it and then masked up the holes and bolts.
2. Painted it with VHT Wrinkle applying 3 generous coats, 5 minutes apart in a crosshatch pattern (first coat horizontal, second vertical, third diagonal ensuring all the hard to reach areas were covered)
3. Let it sit for 4 hours in room temp until it was touch dry. (You'll notice the paint will already start to wrinkle at room temp, however avoid contact with the surface even if it appears dry) Removed the masking tape, chucked it in the oven for 30mins at 95 celcius (~200f) to allow the paint to cure/wrinkle.
4. Removed it, let it cool for an hour or so, then sanded back the raised sections in the same method as earlier.
That was pretty much it, and for a first attempt, it came out perfect. I would recommend getting the raised areas to a polished finish before painting, as it makes it a lot easier to sand/polish after painting.
Posted: May 07, 2010 1:48 AM
by Scottinva
Awesome thanks! I have always wanted a powdercoater, but no room for an oven in the garage. I may start putting painted parts in my oven! Looks awesome, thanks for explaining what you did.
Posted: May 07, 2010 1:54 AM
Scottinva wrote:Awesome thanks! I have always wanted a powdercoater, but no room for an oven in the garage. I may start putting painted parts in my oven! Looks awesome, thanks for explaining what you did.
No dramas mate, it's a lot easier than i first expected, and i'd definitely recc. giving it a crack. A tip though, check to see if the valve cover will fit in the oven before painting :laugh: I painted and then realized it didn't quite fit, so i had to cook it with 1/4 of it sticking out, luckily the latent heat was enough and it wrinkled evenly all over! :alright:
Posted: May 07, 2010 8:50 AM
by TSMacNeil
Looks very nice...and thanks for sharing the steps and temps for the "cooking"
Posted: May 07, 2010 9:48 AM
by Auke
Very nice done! :cool:
Posted: May 07, 2010 10:15 AM
by skip535i
Nice work, Christian.
Posted: May 08, 2010 7:18 PM
by Jase
Want to come over and do mine?
Posted: May 08, 2010 10:06 PM
Jase wrote:Want to come over and do mine?
I was actually thinking of doing a wrinkle coating service for local guys if they're interested, had a few fellas from the car club inquire about it. Would be a pleasure to spruce up another e28 :cool:
Posted: May 08, 2010 10:51 PM
by bradwood
That is nice mate, well done!
How long overall did it take you ie how many days was the cover off the engine?
Posted: May 08, 2010 10:59 PM
bradwood wrote:That is nice mate, well done!
I sanded it, painted it and polished the raised sections in a single day, but had to wait for the gasket to come in from BMW, however if i'd had that from the start it could be done in a single day, or easily over a weekend.
Posted: May 09, 2010 3:14 AM
by Jase
Das_Prachtstraße wrote:I was actually thinking of doing a wrinkle coating service for local guys if they're interested, had a few fellas from the car club inquire about it. Would be a pleasure to spruce up another e28 :cool:
let me know should you choose to offer that and how much you'd be charging. Need to improve it a little bit more before I feel like I've done it justice, and with work and stuffs, I've got minimal time to do stuffs myself, unfortunately.
Posted: May 10, 2010 1:15 AM
No :facepalm: here, very very :cool: .
Posted: May 10, 2010 5:09 AM
So i pulled my finger out and did the plenum too, and I'm glad i did as it turned out very well. Now to clean up the rest of it before dropping it in the car.. sigh.
