WTB: Fuzzy Body seals for door frame
bac914
Post by bac914 »
Seeking all four fuzzy door seals that sit on the frame, but front are priority.
Thanks,
Brian.
lmc337
Re: WTB: Door Seals and Rear Bumper Pad
Post by lmc337 »
The "mouse fur" or the seal on the actual door - i should have all 4 of the ones on the door, and do have a rear bumper pad (Impact Strip).
Let me know, and i can get it all pulled this weekend to ship Monday.
Lee
bac914
Post by bac914 »
I meant the stuff on the frame, not the door, so yes the mouse fur. Is that seal and the mouse fur a separate piece or does it come as one? Was assuming it's all one. That's what I need.
Can you pm me a pic and price/shipping/80123 of the bumper pad?
Thanks,
Brian.
truckerwillie
Door seals
Post by truckerwillie »
If other poster has not bought, I need both right side rubber seals.
1986 535i.
truckerwillie70@yahoo.com
lmc337
Post by lmc337 »
PMd OP
Door rubber, right, on the door, not the chassis mouse fur? And right as in passenger side? (always helps to be sure)
truckerwillie
Door seals
It is the seal (mouse fur?) attached to the body. I see now that thr rubber seal is attached to the mouse fur. I need both RS (passenger) front & rear. My car is black inside if that matters.
lmc337
Re: Door seals
Post by lmc337 »
truckerwillie wrote:It is the seal (mouse fur?) attached to the body. I see now that thr rubber seal is attached to the mouse fur. I need both RS (passenger) front & rear. My car is black inside if that matters.
doesn't matter, as I stated above, I have the seals on the door, not the frame. Good luck hunting.
truckerwillie
Door seals
Thanks for your help.
Truckerwillie
87royal
Post by 87royal »
Who still needs this? Going to check the condition of the spare set I have.
My E 28 533i
Post by My E 28 533i »
I need them too.
truckerwillie
door seals
I need psgr side front and rear, if available.
truckerwillie
1986 535i
bac914
Post by bac914 »
I'm still looking for a good bumper pad and the "inner" door seals, the ones on the frame with the mouse fur.
Thanks,
Brian.
bac914
WTB Fuzzy body seals for door frams and bumper pad
Post by bac914 »
Updating subject as it appears I didn't state this correctly and I may not be catching the right folks' eye.
Looking for the fuzzy seals for the door frames and a good condition bumper pad.
Thanks,
Brian.
GaAlpinaOwner
Post by GaAlpinaOwner »
What the heck part number is this? Are we talking about this?
http://www.realoem.com/bmw/showparts.do ... g=51&fg=55
parts 1&2?
bac914
Post by bac914 »
Yes that's the stuff. 51721904328 and 9.
Thanks I couldn't find it in the catalog.
I see that several of us need this stuff.
GaAlpinaOwner
I suggest everyone go put these on B/O with a dealer. This is the only way they will make more. I did
lmc337
Post by lmc337 »
PM'd Brian to advise of the 'need' - official response below:
Parts Dept wrote:They have been on backorder since June. We play the waiting game.
jwhiii
Post by jwhiii »
The RealOEM diagram is confusing. Item 1 points to the Driver's side front and passenger's side rear. Item 2 points to the Passenger's Front and Driver's rear. It is the same on Max Imports. Is this an error?
Also, these are some high dollar parts due to limited availability. Almost a thousand bucks for all four! Anyone find any alternatives, my fronts are pretty ratty.
John in VA
Post by John in VA »
jwhiii wrote:The RealOEM diagram is confusing. Item 1 points to the Driver's side front and passenger's side rear. Item 2 points to the Passenger's Front and Driver's rear. It is the same on Max Imports. Is this an error?
No, that's correct. That makes the fuzzy bit be on the inside.
yomenendez
The Fussies
Post by yomenendez »
Just had to pull my fussies off the rubber edge...faded,torn and rotten after 22 years. The way I look at it....it is just more of BMW Shadowline Trim to look at...especially if your interior is black...the only really unsightly view is at the bottom of the B pillar...Good Luck
bac914
Post by bac914 »
still looking for these if anyone is parting out a car and has some....otherwise still waiting for the parts guy to hook us all up....
Thanks,
Brian.
Parts Dept
Post by Parts Dept »
I check the order just about every day to see the status. They are still on the order list but no ETA yet. (sigh)
ElGuappo
Post by ElGuappo »
I generally pull the mouse fur off, looks better without it.
Just a clean blakc rubber edge.
Heres a thought too: The e23 door surrounds work on the E28, and they go ALL the way around the door to seal it. You just have to modify the sill piece.
Parts Dept wrote:I check the order just about every day to see the status. They are still on the order list but no ETA yet. (sigh)
I'm guessing they'll finally cough up a few sets in about the year 2050, when none of us care anymore. :)
gmb49all
Post by gmb49all »
I have a set, PM me for a price...
