Post by rmiddendorf »
Well lets see if this grows legs. And it will give Duke a thread to add to.
On my E90 I vacuumed the entire car and the floormats, treated the dash, cleaned the windshield, installed a new jack pad for the drivers side (they're plastic and eventually wear out when you use a cheap jack like mine), cleaned the trunk, and swapped out the snow tires for my summer set.
:banana:
I also swept out and vacuumed the garage so I wouldn't be crawling all over salt and grime.
belch9
Post by belch9 »
Swapped out the winter tires for the summer tires on the 2009 E90.
I took the Subaru to the dealer so they could perform a service which means that I know am forced to drive my e28 :ohyeah:
booker
Post by booker »
Bought a belt and alternator for my F250.
Picked up my E24 dash cover from the mail :heehee:
Post by slammin_e28 »
Drove the poo poo out of the e46 as the headers make it oh so nice and raspy!!!
:haul:
Removing 7 years of dead paint to bring back that drippy, fresh from the factory gloss.
winfred
Post by winfred »
drove the e30 all over town with its freshly rebuilt blower i installed yesterday, HO impeller good :D
Aired up the left rear snow tire on the e32 for (hopefully) the last time. There is snow in the forecast for tonight*, so I'm keeping the ratty old nearly bald Blizzaks on for now, but will roll the dice and put the BBSs back on this weekend. Will definitely get those things replaced before next winter!
* Yes, snow in the forecast, at the end of March. Not the latest I've seen snow, but it's still annoying as all get-out. But I'd like to have a word with that frickin ground hog!
bojangles
Post by bojangles »
short answer - remove alternator
long one:
remove engine cover,
detension serpentine belt
unhook belt from alternator
remove airbox
remove air snorkel
remove battery - charge it cuz it is dead
remove battery box
remove fan control module
drain coolant
remove rigid coolant pipe
remove thermostat housing
remove associated hoses
Lift out double fan assembly - bend and fight it all the way
disconnect alternator wires
unbolt alternator
djazz
Post by djazz »
Added washer fluid to the truck. Does that count? Oh and I bought a new gas can and put air in the mower tires.
On a related note, Cindy decided to scalp the front yard and took out three sprinkler heads. Joy.
dj
Took the battery out of the ix.
She's next in the chute for some love...
Bearings, boots, brakes, koni SAs, tuneup, timing belt, etc.
MATCHING tires...
winfred
Post by winfred »
ya gotta put the air in before :rofl:
djazz wrote:Added washer fluid to the truck. Does that count? Oh and I bought a new gas can and put air in the mower tires.
dj
Patrick McHugh
Post by Patrick McHugh »
Put air in the wheelbarrow tire
Blue Shadow
Post by Blue Shadow »
Put air in the leaking mower tire.
Replaced the leaking front shock (puddle of oil under it meant it was time to change it). Also did the other side. This shock had lost it oil and had no internal friction. Jeep rides a bit better.
Now I am on to breaking the four bolts holding the top of the rear shocks, punching out the capture nuts welded to the support and pulling in some bolts with string to replace the rear shocks.
I might actually like driving the thing again.
Tammer in Philly
Post by Tammer in Philly »
ahab wrote:Removing 7 years of dead paint to bring back that drippy, fresh from the factory gloss.
Awesome! When do I drive it again? :-)
Over the past couple weeks, I've detailed the E34 engine bay (round one of probably 4 or 5 to get it looking as I want it to look--should be enough to identify the source of my oil leak, though). Full interior detail, wash, wax.
Upcoming work: full exterior detail (clay, polish, seal), re-spray nose panel (front-end respray is flaking off that piece), replace some steering components and rear shock mounts, fix bent BBS RX, plug two summer tires that have screws in the tread.
-tammer
Gelatinous
Post by Gelatinous »
continued to search for 6" wide fender flares to cover the 265/75 R16's on my Suzuki Samurai. Don't particularily want to pay $500 for them......
also started the '68 Dart 270 after having been sitting all winter, didn't even need to boost it :)
djazz
Post by djazz »
winfred wrote:ya gotta put the air in before :rofl:
dj
If only I had known. :roll: Probably wouldn't have helped anyway as she was scalping on purpose to clear out a few years worth of debris.
Sprinklers are due to be replaced anyway. The system is leaking all over the place and the controller was a rainbird original prototype I believe- runs on plastic clockworks worse than an E28 odo.
philip1
Post by philip1 »
I looked at it and thought "man I was dumb buying that heap of junk."
Sent 2 Grand Wags to the crusher. got good money for them too :banana:
Bill in MN
Post by Bill in MN »
Bled the cooling system in the track car. Sat in it and made Vroom Vroom noises :banana:
Put the battery in the Baur
Started the e24for the first time since Sept.
Looked at the Cozzie, swore at it.
Gassed up the motorhome, swore at that too.
87royal
Post by 87royal »
For the E36
a wrote:Sent 2 Grand Wags to the crusher. got good money for them too :banana:
I flipped 2 Wagoneers a few year ago for a $4k profit. . .are you sure there wasn't any goody left? They have a strong following, almost like an odd boxy German sedan we all know and love.
sQuirly
Post by sQuirly »
put a bronzit personality contour in the trunk of Jetta while hauling the shell of the parts car to the scraper.
I find I treat my new car like a beater and my e28 like I should treat a new car.
