I can make these for you! Stealth sub boxes.
I made one of these for Austin8753 as a stealth sub box install. It was soopa easy and I can make one for you too if you want one.
It's sized to fit up against the back of your rear seat with a panel to make it look like it's not even there. This is a 12" sub with a 1.25 cuft volume. I can make it for any size sub with the proper interior volume. It's sealed tight as a virgin's honeypot and has gold plated connectors. 3/4" MDF sealed with caluking on the inside. The carpet overlaps on the sides to cover the gap for a clean look. Carpet on the bottom to add some grip on your trunk carpet. I suppose I can make a ported box too if you really want it.
Of course it won't come loaded with a sub. Sized to fit under a rear strut brace. I would need the height from floor to the bottom of your brace if you have one since many are different. Room on the sides for mounting crossovers. Or I can have the box all the way over to the side and have room for amps mounted out of view. But I like under the rear seat for mounting amps.
$150 plus shipping from 97220 If you are going to 5erWest, order one now and I'll bring it.
I have tried....but the angles, clearences, space restrictions are a pain in the ass to deal with. Big time pain in the ass. I know there are people htat have done it. I just don't want to deal with the hassle. Plus you wouldn't be getting the proper interior box volume to maximize the sound of your subwoofer.TucciRW wrote:You wouldn't have ay experience with fabricating a sub enclosure for underneath the drivers side rear seat, would you?
It's just a matter of finding the ported dimensions. Not a problem. I have the technology to do so. If you say do it...I will.rojacob wrote:I agree. The sub i have is in a vented box. If theres a way can engineer a vented box (with correct chamber dimensions) i would be in.Paul in N FL wrote:Hmmm, I definitely like that and if I were to get one I'd want it ported. But as of this moment, I have no fundage.
PM me.
I also will add that I also I cut a hole in the rear firewall to let more bass through in to the cabin. Right behind the rear armrest.
What's the use in installing a sub in a trunk which is sealed from the passenger compartment? For the sub to function correctly and get the bass into the passenger compartment you'll need to cut an opening into the rear bulkhead. Something about the size of the cutout needed for the ski bag option.ilikemybike wrote:Plus you wouldn't be getting the proper interior box volume to maximize the sound of your subwoofer.
Just my $.02
Rich
That's just what I did.Rich Euro M5 wrote:What's the use in installing a sub in a trunk which is sealed from the passenger compartment? For the sub to function correctly and get the bass into the passenger compartment you'll need to cut an opening into the rear bulkhead. Something about the size of the cutout needed for the ski bag option.ilikemybike wrote:Plus you wouldn't be getting the proper interior box volume to maximize the sound of your subwoofer.
Just my $.02
Rich
Rich Euro M5 wrote:For the sub to function correctly and get the bass into the passenger compartment you'll need to cut an opening into the rear bulkhead.
Not exactly.
The sub-100Hz stuff will pass through the bulkhead without much loss at all. And with the speaker in the same plane as the bulkhead, you may actually get low end radiating from the entire bulkhead, which could be a good thing (or could cause lots of rattling).
If you want to cut a hole into the cabin, I'd think the best choice would be to build a compound enclosure that vents into the area behind the rear armrest.
podgorny wrote:If you want to cut a hole into the cabin, I'd think the best choice would be to build a compound enclosure that vents into the area behind the rear armrest.
Still thinking about this. Surely someone has built a system that uses the trunk as the sealed chamber and ports into the cabin.
I've been looking at this subwoofer:TucciRW wrote:You wouldn't have any experience with fabricating a sub enclosure for underneath the drivers side rear seat, would you?
http://www.crutchfield.com/s_130SW841D/ ... D&skipvs=T
It seems to get pretty good reviews, is very shallow, and from what I've read the ideal ported box size is 0.4 cubic feet, which should be achievable under the rear seat. I just haven't designed the box yet, or bought the sub, or bought my new head unit, or my new speakers. Other than that, I'm almost there!
That's the sub member PMA has under his rear seat in a small box. I built him a box for his second sub that fits under his passenger FRONT seat. It sounded just fine.desmofan wrote:I've been looking at this subwoofer:TucciRW wrote:You wouldn't have any experience with fabricating a sub enclosure for underneath the drivers side rear seat, would you?
Since a PO cut three holes in a triangular pattern, in two different locations of the trunk bulkhead, centered on each rear seat passenger in the M5. I've given some thought to building a sub with a passive radiator, most likely built around 8" components. My idea is to cut out two openings just large enough for the sub and radiator, centered on the existing holes, and have them bolt up to a properly designed enclosure mounted on the trunk side of the bulkhead.podgorny wrote:podgorny wrote:If you want to cut a hole into the cabin, I'd think the best choice would be to build a compound enclosure that vents into the area behind the rear armrest.
Rich
This is exactly what I plan on doing, except I may make it a vented box; haven't decided yet. I did find it on Ebay for $80, which is a great price. I'm thinking of buying my head unit at Crutchfield though, to thank them for all the research I've been able to do on their site, and they're price is decent.
I have a box that does JUST this for my E34...there is a guy building them for people on bf.c and r3v.podgorny wrote:podgorny wrote:If you want to cut a hole into the cabin, I'd think the best choice would be to build a compound enclosure that vents into the area behind the rear armrest.
For twice my price.skip535i wrote:I have a box that does JUST this for my E34...there is a guy building them for people on bf.c and r3v.podgorny wrote:podgorny wrote:If you want to cut a hole into the cabin, I'd think the best choice would be to build a compound enclosure that vents into the area behind the rear armrest.
Imma gonna say the latter:skip535i wrote:Your box isn't ported...or did I miss something?
ilikemybike wrote:It's just a matter of finding the ported dimensions. Not a problem. I have the technology to do so. If you say do it...I will.rojacob wrote:I agree. The sub i have is in a vented box. If theres a way can engineer a vented box (with correct chamber dimensions) i would be in.Paul in N FL wrote:Hmmm, I definitely like that and if I were to get one I'd want it ported. But as of this moment, I have no fundage.
PM me.
PMing- very interested. I have an amp in the way, then need another amp for the sub- you say there are room for both of them under the rear seat? I haven't even looked- I know, lame.
I think I like the sealed box, and yes, a thin piece of sheet metal isn't going to slow down anything under 100hz, but then again, since my other speakers stop at 200hz, that means we NEED that 100-200, so the hole might be needed, and the sub crossed super high.
That is of course, for the full-range crowd. Most stereos I hear these days are only concerned with woofs and tweets. My $.02
For an E28 box, Luke charges $250, you have to have at least 4 orders in to make it worth his while and they wouldn't be ready 'til well into summer. I'm not hating on the guy at all; he makes a sweet box, but I think this is a better solution to my needs. Plus, I like supporting a local business!skip535i wrote:I have a box that does JUST this for my E34...there is a guy building them for people on bf.c and r3v.podgorny wrote:podgorny wrote:If you want to cut a hole into the cabin, I'd think the best choice would be to build a compound enclosure that vents into the area behind the rear armrest.
Jeff, thanks again!
