4 holes to give reason to changing your timing belt
Hi, I was taking a head off a m20 from a e34. I bought the car to part out. I was told that it had a blown head gasket. Well I have never seen a gasket go like this. I did not count but a number of rockers broke. 6 valves broke, one stuck in a piston. 4 out of the 6 pistons had holes in them.
Remember change your timing belt.
Andy
Andy
My e30 had a "blown HG" but it was just the valve cover gasket and half moon seals leaking.Cactus wrote:I love how people will blame anything on a head gasket. The kid I bought my old saab from said it had a blown headgasket. It had actually spun a bearing and ruined the crankshaft flange.
I had those laying around, so no cost to me!
HG huh? You would think the complete lack of vacuum pressure to the brake booster would have been a dead givaway it was something much, MUCH worse.
The holes remind me of the untimely end of my XJ-6. Yes, it had chains and half a million chain guides. I hated that engine and it's 10 miles of vacuum lines and crap guides, but it actually broke because of faulty tappet guides coming apart and allowing the valve to shake side to side until the head breaks off (a "hold down kit" aka band-aid was made by a local shop here that required machining the head to accept the bolts for the kits at arm+leg prices for each two guides it held down). Vacuum pressure? What vacuum pressure? I managed to drive it home on 5 and a quarter cylinders knowing it was unrepairable when it went with almost no brakes. Parted the car for more than I paid for it a year prior.
Et Tu, Snakeyes, had an XJ6 as well? That is 3 cars we have in common. Is there an emoticon for high five?Snakeyestx wrote:HG huh? You would think the complete lack of vacuum pressure to the brake booster would have been a dead givaway it was something much, MUCH worse.
Perhaps this should be stickied so the pictures can be referenced quickly for newcomers who question the "change your timing belt" mantra.south26 wrote:Finely took this piece to the junk yard. once again here is a reminder to change your timing belt.
Andy
Any chance you could upload larger pictures?
- Beamter
