[/quote
[/quote
Post by Coldswede »
For some reason when I try to use the Quote function lately the closing bracket is not being entered automatically. I have to close it manually.
Is this error on my end or something amiss in the quote function?
Justin_FL
MyE28 IT Guru
MyE28 IT Guru
Re: [/quote
Post by Justin_FL »
It only works if you use it to place an initial tag and then click again to close.
Are you using it when quoting someone else's post with broken quote tags?
WilNJ
Re: [/quote
Post by WilNJ »
Justin_FL wrote:It only works if you use it to place an initial tag and then click again to close.
test
Wow...in 2 years of posting, I never paid attention to those buttons.
Thanks, now I need to go find other posts to quote, bold, italicize, underline and make lists on.
Re: [/quote
Post by Coldswede »
Not sure Justin, I didn't notice anything wrong with the post I was quoting. I'll just keep an eye out for it happening again, then copy paste the whole thing here
[quote="Jeff Ireland"]
It works fine. Your computer is the issue.[/quote
:rofl: :rofl:
