Moved back east. Less than 150 miles from Sweeney's! Old timers no what this means!
Towing the car to Sweeney's next weekend. Engine arrived this morning.
Here is the current plan:
Engine is a 2007 L33 all aluminum 310/335 in truck form. This engine is known as the 5300 HO and has some goodies from the factory. It has ls6 heads and valve train. slightly higher CR at 9.9 to 1 and a hotter cam than the other 5.3s.
We'll be installing new factory mls headgaskets and ARP studs. Otherwise the engine will remain stock. A BBK intake, 50lb injectors, early Corvette LS1 fuel rail, and f body throttle body will all be used.
Peter is providing the MS3 and flying lead harness. I'll be terminating the harness.
The t56 should arrive next week. Clutchmasters will provide the clutch kit. Hurst shifter. 346lsd is enroute.
Planning on a single turbo in the short term. We'll look at building prototype twin manifolds if space allows and bring them to production next year. Will be using a T04S, 67mm billet wheel, journal bearing, P Trim and .96 tang housing.
Plan on running 6-7psi for 450/500 to the ground.
