Dieselboost's 524compoundTD
DieselBoost
Post by DieselBoost »
at this time power goal is about 350hp but that engine is very heavily modified.
i just came to home from carage
now there is the 12mm rotorheadpump and i found that my 524TD goes nuts with that :D
allmost shitted to pants....that power is awesome :D
when is was taking 191hp from stock ip there was 1.9bar boost...it is too much but time was running out and i was thinking that makes maximum power.. so it was more easy to run with big boost.
now i have 2.0bar boost with 12mm rotorhead...
engine temperature stays under 90C
exhaust temperature stays under 700C
exhaust pressure stays same what the boost is.
i think this is big success from me
now i must buy a new waterhose...again OLD waterhose exploded.....im thinking how stupid i am when i use those :facepalm:
Zubcho
Post by Zubcho »
Something new about the project?
Can you tell us the detiled list of the parts that you used and some prices of the parts :)
DieselBoost
Zubcho wrote:Something new about the project?
yes i can...not now but soon.
btw... mild engine exploded...
caused by wastegate malfunction boost was about 4bar and headgasket explodet out...
feels little bit stupid because that happened....so next time i will keep eye on gauge...
interesting thig is that my engine last for 15min before explosion...and water temperature was 85-90c so cooling works fine...
ext gas temperature was about 800c-900c
and base engine was stock..
now im changin new gasket and ready to roll again...
at same time im working with super engine....
Frybrid 524td
Post by Frybrid 524td »
What new head gasket are you using? Anything special or just a stock gasket?
DieselBoost
Frybrid 524td wrote:What new head gasket are you using? Anything special or just a stock gasket?
Stock...because i have one spare
mls gasket is good...but for this engine it is too expensive..
my friend 524td engine is now worked over one year with stock gasket.
power is about 200-250hp and boost 2bar
Zubcho
Post by Zubcho »
4bar COOL :alright:
I'm impressed.
DieselBoost
Fun with my friend car...(me driving)
1.6bar boost
i can reveal...this car is builded from junkyard/trash parts :D
turbo is now new...not anymore 3fd.. :D
now there is Garrett t04b/t04e hybrid...ofcourse turbo parts are from junkpile :D
so littlebit imagination and this you can get for cheap :)
http://www.youtube.com/watch?v=lIV3v1V7__Q
DieselBoost
So... i repaired my junkpile again.
cyliderhead was totally like a corkscrew caused by heat.
but now it is machined again and engine is running good.
there is one stupid thing to change....there is now fuel pump in tank to getting more fuel for ip but hoses are wrong...
pressure is going to re-circulatingline and leaking lot of fuel out. :facepalm:
CoyoteStarfish
Post by CoyoteStarfish »
I hate to make you repeat yourself DieselBoost, but can you go over the modifications you've made to your injection pump again?
I'm getting ready to look for parts to modify my injection pump (12mm head and rotor, 2.8 or 3.2mm cam plate, etc)
DieselBoost
CoyoteStarfish wrote:I hate to make you repeat yourself DieselBoost, but can you go over the modifications you've made to your injection pump again?
In my ip is cummins 12mm rotorhead.
but there is adjustments wich i cannot tell anything...because guy who made my ip cant tell me anything....secrets....he say.
but use stock cam plate... i use that too. there is only problems if you use steeper plate.
steeper plate fits nicely to low rpm engines like cummins.
just thinking if my ip cant produce fuel amoun what i need, then i will use mb 300tdt ip maded by mynädiesel with 7mm plungers.
CoyoteStarfish
From what I understand, as long as you supply enough pressure and volume of fuel you can run larger cam plates without loss of high end power. On a forum for Cummins engines someone suggested that if we could supply enough pressure and volume of fuel with a quality lift pump and fuel regulator we could run 4mm cam plates. That is a little crazy in my opinion, I would be happy with a 2.8/3.2mm plate used in a stock Cummins, and just supply it with adequate fueling.
Also take a look at this:
http://www.youtube.com/watch?v=LbG4INpF0Ks
Looks like a M21 engine with a heavily modified P7100 injection pump, is that what you're thinking of doing?
DieselBoost
yes that is roosamaster pump....that guy who own that car wrote me in youtube..
but yes mercedes row ip.
DieselBoost
new video in daylight
HERE! http://www.youtube.com/watch?v=3pI6qduZ3jM
Alleslowbuged
Post by Alleslowbuged »
Hi,
like that "tractor" sound of a M21 with a straight pipe.
Funny, that you also lost a headgasket though a wasetgate problem, i have lost my second headgasket 2 or 3 hour after restart the engine, because a small boostpipe for the bosstcontroller has get a leakage and i have driven on the autobahn with whatever boost pressure.
Did you have shedule to go on the dyno agian, i would really love to know how much power increases through the the 12mm plunger.
I was on the 1/4 mile this weekend, but could not really decrease my toptime, best run was a 15,2s. Did you was on the dragstrip with your bimmer?
@CoyoteStarfish
In summary you have to make 3 major mods on a pump:
1. bigger plunger for faster injection
2. more advance timing for good high rpm power
3. governor mod, for more fuel at higher RPM than 3500
The hardware mods are not that difficult, if you have the necessary tools, but to find a good setup without a test device and/or a lot of experiency will be nearly imossible. I have 10 years of pump experience and still working since last christmas on my vw pump, to find the best hardware combination and a good setup. The last pump change has been finished in 55min between engine stop and start, so you could imaging how often i have dismount the pump since christmas.
Best Regards from germany
Alleslowbuged
DieselBoost
i think im not going to dyno in this moment.... because i will use max 1.7bar boost now.
in finland one 324TD e30 has 12mm plunger with 1.6bar boost and 245hp
i was in dragstrip, but fuel liftpump failure ruined that day. so my car was only in parking lot.
but my friend has 15.6sec time with top speed of 159km/h
and....it was rainy day...so no grip untill 4gear
i think it was quite good time for those weather conditions.
Alleslowbuged
Hi,
i drive also max. boost pressure of 1.6 - 1.7 bar in my car. Is the gearbox and differential stock in the car of your friend? The top speed of 159 km/h sound really really quick and should bring a time of below 15s, my top speed is arround 135km/h up to 140km/h, either with a differential ratio of 2.93 or with stock ratio of 3.15.
Why don`t go on the dyno with 1.6 bar, i would really love to see the different in peakpower and also in the power curve vs. engine speed.
Best Regards and always a tight headgasket
Alleslowbuged
DieselBoost
gearbox are stock (260) but differential is from 520i
time will tell... there is waiting list of months in dyno....so maybe later.
whatever in next summer i have totally new engine. so then we are talking power seriously.
now there is too small turbo, so i cant get more than 250hp.
DieselBoost
check out our facebook group Team3fd
there is our cars.
updating is little bit slow, sorry :D
altus22
Post by altus22 »
How much intercooling do you have? Is it water to air or air to air? Do you know what your peak intake temperature is?
DieselBoost
altus22 wrote:How much intercooling do you have? Is it water to air or air to air? Do you know what your peak intake temperature is?
i dont remember measures. (see my project pics)
but less.
ic is custom made for my car. by erikoishitsaus raatikainen who make coolers for racing cars.
he is one of the bestest aluminum welders in finland.
so i dont use china coolers.
but ic is quite large and very effective.
ic is air to air type....i have no use for air to water. only dragcars and pulling tractors have benefit of that type ic
DieselBoost
Now we are talking about serious shit...
while im working with my 524TD
in same carage is something else...
it is Mb 190 300superturbodiesel project of my friend.. actually same guy who owns that other 524TD..
in mb is about 400whp now.
this is only mild test drive. we tested it in asphalt and there wasnt any grip when accelerating full power from 80km/t speed with 4th gear.
http://www.youtube.com/watch?v=tOvmMgQt9oI
http://www.youtube.com/watch?v=fAGidcDBK10
Zubcho
Post by Zubcho »
wow :shock:
DieselBoost
Okay AGAIN! i must slow down my project...
Out of money
:x
DieselBoost
Juts discovered more broken waterhoses from my car :facepalm:
and second irritating thing..... expansion tank pressure cap is not working properly.
i can only say....upper waterhose was like a piece of rock.
anyway...engine is running fine now, only must get new cap for expansion tank and few new hoses.
in next engine.....i will make waterpipes not bloody hoses DAMN THOSE HOSES!!!
DieselBoost
attlast winter came.
So i tested my oilburner
-12c temperature, no block heater, summer type diesel, dry fuel system....
http://www.youtube.com/user/boostturbo? ... sAp6Tx-MYY
then strikes summer type diesel
http://www.youtube.com/user/boostturbo? ... rpsbGCdtHU
