Relay question (4 & 5 prong part links in post)
Twglace
Post by Twglace »
Any one know what the two metal relays with 4 prongs and 1 small prong are for? They sit in front of the fuse box close to the battery... AND does anyone have a labeled picture of all of the relays... My car has a serious case of the gremlins... Image
P.s I'm also looking for locations of all the ground connections and the part#s for all of the straps.
Juanwick
Re: Relay question
Post by Juanwick »
Left one is the fuel pump (lift pump) relay. Right one is the main relay.
tn535i
Re: Relay question
Post by tn535i »
Get the ETM at wedophones, it is a map to chase gremlins, then check out the wire colors on the sockets and match the schematics. Otherwise you are hoping someone else's guess is correct. They are not labelled and they may not be in the same order on every car.
Twglace
Re: Relay question
Post by Twglace »
Juanwick wrote: Jun 18, 2021 11:16 PM Left one is the fuel pump (lift pump) relay. Right one is the main relay.
Would you happen to know what the part number is for both relays? I can't find any with the right 5th pin...
Twglace
Re: Relay question
Post by Twglace »
Thank you very much
