https://youtu.be/_PC0a5I4408
List of materials used to paint the car just missing the primers used I have he receipts somewher.
EW Midnight Metallic Black Basecoat Gallon 54220
EW Low VOC Urethane Activator Qt Medium
SpeedoKote SMR-0075 - Zero 0 Low VOC Compliant Thinner Reducer Medium 70-80°F, One Gallon
Paxcoo 85Pcs 400 to 3000 Grit Wet Dry Sandpaper Assortment for Automotive Sanding Wood Finishing
SEM 39143 Trim Black Aerosol - 15 oz.
3M 39060 Perfect-It Rubbing Compound - 16 oz.
Perfect-It 3M 39061 Machine Polish - 16 oz
Summit Racing
SUM-SWSC620G-12
Paint, 2-Stage, Low 2.1 VOC, Gloss Clear, 1-Gallon
(Mfr. #: SUM-SWSC620G-12)
Summit Racing
SUM-SWSH622Q-12
Clear Coat Hardener, 2-Stage, 2.1 VOC, Medium, 1 Quart
(Mfr. #: SUM-SWSH622Q-12)
I forget the brand of primer we used, but we did use a etching primer and primer sealer. As well as tack rags to wipe down the car before spraying.
And my favorite
