OBC calibration
OBC calibration
I'm trying to retrofit an OBC on a 1983 528e, and the average mpg and mph are totally off. Does any have info on (re)calibrating the OBC?
Re: OBC calibration
Make sure you have the correct coding plug.
Re: OBC calibration
There is a small adjustment screw located behind a plastic cover in the lower left hand corner of the OBC. When the low fuel light first comes on (the warning light in the fuel gauge), the tank should have 4.5 liters of fuel left (I'm not entirely sure about this value - others on the UUC digest have suggested that the proper value is more like 6.5 liters, so who knows). Make sure the car is parked on a level surface, and then turn the little screw until the display reads 4.5L.
Re: OBC calibration
This is for the OBC II. I expect the op in an 83 has the earlier one but he did not state OBC II and is retrofitting the unit so unknown which one specifically as the II was very common the earlier one not so much.John in VA wrote: Sep 05, 2024 8:30 PM There is a small adjustment screw located behind a plastic cover in the lower left hand corner of the OBC.
The manual says 1.8g or 7l is the illumination point in the later E28 owner's manual. The ZA E23 manual says just shows a range of kilometers. 1.8g converts to 6.81 liters so your 6.5 is as accurate as BMWs conversion.
Re: OBC calibration
Sorry for the lack of specificity. The OBC came from a 1987 535i, so I would assume that John in VA's comment/instruction applies.
I'll give that a try.
Thank you gents!
Thank you gents!
Re: OBC calibration
How can I get my hands on this manual, is it the TIS?Blue Shadow wrote: Sep 06, 2024 1:13 PM The manual says 1.8g or 7l is the illumination point in the later E28 owner's manual. The ZA E23 manual says just shows a range of kilometers. 1.8g converts to 6.81 liters so your 6.5 is as accurate as BMWs conversion.
Thanks
