Again. Thermostat help
Re: Again. Thermostat help
Thanks for that side by side comparo @e24mpwr
Great pictures and reference for the future.
My pleasure - this place has contributed to me in so many ways I can't even count.slownrusty wrote: Oct 02, 2021 9:00 AM Thanks for that side by side comparo @e24mpwr
Reading the whole thread again, some other/additional thoughts:
- The QH seems to be the "Early M30" style with the larger/35mm block-off plate - so from the sound of the thread works, but with "faster warm-up" (in quotes because I'm not entirely sure what that means or the impact of it)
- Obviously the Vernet isn't an "exact visual match" - I might be misremembering his words, but it is pretty clearly dimensionally similar or the same, albeit with a very different design and construction.
- The Vernet is working fine for me
- The Calorstat/Vernet TH1528.80J can be found on ebay fairly easily for under $30 delivered, but my searches on the part number all show up from European sites.
- My shop was able to have it delivered, so I don't think they're hard to get (possibly enabled by the next point)
- Note that ebay listing also states it's for a mid-late 80's Jeep Cherokee. I'm not sure if that's a useful tangent or not, but it's an amusing one
- I was able to find the TH1528.80J on CarID for $15 (before shipping)
Cheers!
Ahh I have just order 2 thermostat from Pelican so the chances are they are very likely won't fit?
https://www.pelicanparts.com/cgi-bin/sm ... 7-737-M322
Hey. So what part do I get? I have 4 thermostats and none fit. Any good options?
@e24mpwr. Thanks a great comparison photo.
I might suggest contacting the folks at La Jolla Independent for help/parts.
http://www.bimmerdoc.com/
See the Vernet in my post on Page 1 - fits and working just fine in my M88KDAWG97M3 wrote: Jan 22, 2024 1:21 PM Hey. So what part do I get? I have 4 thermostats and none fit. Any good options?
https://www.mye28.com/viewtopic.php?p=1505182#p1505182
My pleasure - I've gotten so much benefit from this community. Happy to do anything that helps!
FWIW I went through 3 'other brand' thermostats that didn't fit until I tried the Calorstat OEM 80C Thermostat - S38 Engine - E28 M5 & E24 M6 from Bimmerworld which appers to be an exact duplicate of my OEM S38 stat. I also ordered one from Rockauto listed as Motorad but received the identical Calorstat / Vernet part.
Do you mean the one from Bimmerworld had the teepee/tent look like the OE or just measured/fit like the OEM S38? (in other words, are both of the tstats you mention the Calorstat/Vernet part?)kcld wrote: Apr 27, 2024 8:54 AM FWIW I went through 3 'other brand' thermostats that didn't fit until I tried the Calorstat OEM 80C Thermostat - S38 Engine - E28 M5 & E24 M6 from Bimmerworld which appers to be an exact duplicate of my OEM S38 stat. I also ordered one from Rockauto listed as Motorad but received the identical Calorstat / Vernet part.
They were identical in appearance (including the te-pee) and dimensions as far as I could tell.
Can you post their part number? The one I found from Calorstat looks very different (dome vs. teepee), but works fine. I'd love to see one that mirrors OEM...kcld wrote: Nov 02, 2024 10:45 AM They were identical in appearance (including the te-pee) and dimensions as far as I could tell.
