Wasted Spark Install
marc79euro645
Re: Wasted Spark Install
Post by marc79euro645 »
I assume you're using a vr sensor as trigger. You may need to adjust the pots to get stable vr signal. Did this change with the coil packs?
ZenitramNaes
Post by ZenitramNaes »
Brad D. wrote:The timing table shouldn't need any changes, as only the spark energy has changed. It seems odd that you would have stumbling. What are you using for drivers and how are you using the LED outputs to drive them? What code are you using? It's been a while since I updated my firmware and am wondering if there are changes that affect waste spark outputs.
I'm using the BIP373s for drivers. I followed your instructions to a T, it is for a diypnp board but I think I got the same concept across. I'm using the newest firmware, 3.3.2. One of the things I was wondering if maybe the .030 is to much of a gap and maybe that could be causing some of the problem? Lots of backfire, especially on deceleration.
marc79euro645 wrote:I assume you're using a vr sensor as trigger. You may need to adjust the pots to get stable vr signal. Did this change with the coil packs?
Yep, vr sensor with the 60-2 wheel. Before I put in the MSD coil packs it was running of the stock distributor, if that is what you mean.
ZenitramNaes
Previously I was using feeler gauges to measure the gap. I went back over them with a spark plug gap tool and they read .036. I dialed them back down to .028ish and all of the backfiring and weird noises are gone. Still have a bit of stumbling though. The thing I don't understand is that my old spark plugs were the same exact size when I was running the stock distributor. I don't under stand how the stock distributor could cross the gap but the MSD coils were having problems.
marc79euro645
I had to tune the pots on my ms2 to get a stable pulse. read this
http://www.megamanual.com/ms2/vradjust.htm
You should be able to open the plug gaps back, once you get a stable vr pulse. I run .030" on mine with a blaster2 coil.
good luck
marc
ZenitramNaes
marc79euro645 wrote:I had to tune the pots on my ms2 to get a stable pulse. read this
good luck
marc
Would the 1.5v diypnp board have those? I don't think I remember installing any such thing.
marc79euro645
These 2 pots are inside the mega squirt.
ZenitramNaes
I've never messed with the pots before. Is it something I'll manually have to adjust inside the megasquirt or a setting within TunerStudio?
m30b35 turbo
Post by m30b35 turbo »
which pontiac is the coil base from? and where could i get a hold of one? ;)
ZenitramNaes
m30b35 turbo wrote:which pontiac is the coil base from? and where could i get a hold of one? ;)
Not sure of the model, any older GM car will have it. Junkyard is cheapest.
brw71585
Post by brw71585 »
Does anybody have the pics to this post. Looking for reference but can not see the pictures.
RDAvena
Post by RDAvena »
photobucket extension on chrome works for me.
iamcreepingdeath
Post by iamcreepingdeath »
So for cheapskates like me who don't want to spend $66 for each ignition coil, is there any reason I can't go with just a stock coil replacement from a GM car? They are on the order of $15 each on Rockauto. Any reason that wouldn't be sufficient for a boosted M30? Do I need the "extra power" from an MSD coil?
Also, this needs to be a sticky.
iamcreepingdeath
Since nobody answered my question above, I will answer it.
Instead of expensive MSD coils, I used cheap ebay knockoffs, I think for like $67 for the set of 3. (https://www.ebay.com/itm/324537815957)
Obligatory pic.
They seem to be working fine so far, but I started getting another issue, which may or may not be related. I was getting arcing between the aluminum bases of the coil drivers and the heat sink they were bolted to. The arcing was kind of jumping through the mounting hole, past the mica insulator (through the hole), despite using nylon screws.
I fixed it by adding a layer of electrical tape on to the heat sink. I realize this also insulates the heat transfer to the heat sink, but these things don't get all that hot anyway (they are supposed to just be warm to the touch with correct spark settings), so I've been running it like that. Kind of a stupid design for the spark driver to have an aluminum base that is actually electrically hot.
