Page 1 of 4
E28 Turbo FAQ
Posted: Jul 10, 2008 12:28 AM
by Brad D.
Turbo e28 FAQ
-Brad Denton
Last revision 01/08/09
This FAQ is intended as a guide for those interested in venturing down the dark path of turbocharging. It is a very popular subject and many questions are hopefully answered within this FAQ. Hopefully it can be stickied for everyone's reference. I want to keep this page as accurate and current as possible and will gladly make any valid changes, corrections or additions if requested as I want this to be a quality document that guides new converts through their path to turbocharging their car. Please email me at bdenton180sx@removefirst_yahoo.com.
Where to buy a kit?
Turbocharging Dynamics or TCD sells a high quality bolt on kit that addresses all of the issues required to properly turbo your e28.
www.turbochargingdynamics.com
Cartech also still sells kits and components for the e28. Check them out here.
www.cartech.net
What other parts or kits can I use to turbo my car?
You can use parts from BMW's euro only 745i which came turbocharged. There were two engine variations, the m102 and the m106, and are very similar to a normal m30, but there are some small differences. Parts from either version will work to turbo your m30. At a minimum you will need the manifold, the turbo, wastegate and is very beneficial if you have the exhaust downpipe tubes. These parts would allow one to have the basic turbo components and buy the additional components similar to what would come in a new kit or used in a "roll your own" type setup. Better yet, having the entire 745i parts car would make the swap that much easier. It should be noted that the 745i manifold uses 10mm studs for mounting and a standard m30 head uses 8mm studs. The head will either need to be drilled and retapped or adapter studs used. For additional reading on everything 745i, Scottie Sharpe's website is a great resource.
http://bmwturbos.scottiesharpe.com/default.asp
Dinan also offered an m30 turbo kit. It is no longer offered, but occaisionally the used components come up for sale. For those who live in California, the Dinan kit is was and is the only kit that carries and CARB EO number so that it is emissions legal.
Recommended Reading and Relevant Information
There are several books that should be in a turbo enthusiast’s library. These books are great for the novice or the seasoned veteran.
Maximum Boost by Corky Bell.
Forced Induction Performance Tuning by A. Graham Bell.
Turbocharging Performance Handbook by Jeff Hartman.
Here are some other great website resources which include compressor map information as well as "turbo calculators"
Not2Fast Turbo Calculator and Glossary
Garrett Turbo Tech Center
Squirrel Performance Turbo Calculator
Garrett Turbochargers
Can both the M20 and M30 be turbocharged?
Yes, both m20 and m30 powered e28s can be turbocharged. Both engines respond well to turbocharging. There is a specific kit for the m30 powered e28 535i. TCD does not sell an e28 specific kit for the m20, but parts from the e30 325i can be utilized. TCD can advise the user how to proceed. Custom “homebrew” systems have been developed for both powerplants. Since the M20 in the e28 is the same engine as in 325e (and externally the same as the 325i powerplant) there is a wealth of information regarding turboing an M20 on www.e30tech.com whose turbo FAQ can be found here. Most other additional information regarding the M30 will try to be covered here.
How Much Power will my turbo e28 make?
Power levels vary greatly and are dependent on many factors. What octane fuel is being run? Is the car intercooled? What elevation is the car being operated at? From Corky Bell’s book Maximum Boost he cites that from his dyno testing he has seen output range from 0.052 bhp/ci psi to as much as 0.077 bhp/ci psi. For example an M30 has a displacement of approximately 213.6ci. So for 10psi gauge pressure (or 24.7 psi absolute)
you would have power figures similar to those seen below.
Lower Value - 0.052 bhp/ci psia x 213.6ci x (24.7 psia) = 274.3 bhp
Higher Value - 0.077 bhp/ci psia x 213.6ci x (24.7 psia) = 406.3 bhp
While these are theoretical approximations, they will get you in the ballpark to estimate you power output. Todd from TCD once mentioned that on many of the M30s that he had dynoed he will usually see the car put down roughly 12.5hp/psi at the wheels over the naturally aspirated hp. If an M30 makes roughly 155whp NA, then running 10psi boost, it will make 280whp. This estimation will also work fairly well for a turbod M20.
What internal modifications need to be made to the engine?
For many users no internal engine modifications will be required. Both engines are robust units that will tolerate a fair amount of addition power over stock. It seems that the stock M30 headgasket can reliably take 325-350whp with a safe tune. The headgasket can also be upgraded to a Multi Layer Steel (MLS) gasket. Proper RA or, roughness average is also very critical when upgrading as the MLS gasket. A RA of 20 is recommended. A stock head is reported to be in the 45-55 RA range. However, some have used a MLS gasket with head studs with little to no issues.
Stock rods should easily be up to the task in your turbod e28. I do not know of any reported rod failures in a sub 500hp m30. Pistons will also live if detonation is prevented. Power levels approaching 400whp have been accomplished on stock internals.
For those interested in calculating compression ratios of various m20 and m30 engines, you may find my Compression Ratio Calculators useful.
M30 Compression Ratio Calculator
M20 Compression Ratio Calculator
(Right click and Save As)
Where can I find a manifold for my car?
www.666fabrication.com
www.cartech.net
Turbocharging Dynamics ,666 Fabrication and Cartech offer new manifolds for both the m20 and the m30. The m30 can also use the 745i turbo manifold, turbo and wastegate. The m20 can use a modified 524td manifold which required porting of the runners and notching of the flanges to fit. It will accept a t3 footprint turbine housing, but typically required that the turbo be spaced away from the manifold to clear the valve cover. This can make spark plug replacement and valve adjustments difficult or impossible without turbo removal.
Mye28 user Turbodan tried to utilize a 666 Fabrication M20 manifold adapter and was unable to get it to work fit in the confines of the e28 chassis, therefore is NOT a viable manifold option.
There are also several people who have fabricated their own custom manifolds and adapters. The best material for construction is typically mild steel weld-els, typically 1.5”ID Schedule 40.. For reference the m30 cast iron manifolds can be flipped upside down so that a manifold adapter can be fabricated.
There are also a few other turbo manifolds that can be used which are worth mentioning. Dinan's cast manifold which was used in their turbo kit is flanged for a t4 turbo. Alpina offered at least two manifolds that I know of. These were for a single turbo and installed on their B7 series of cars. There was also their twin turbo manifolding used in the mighty e34 B10 TT. These rarely are available used, but they are out there.
What turbo do I use?
If you purchase a kit, it will come with a properly sized turbo for your application. If you wish to select your own turbo, it is highly recommended that you use calculations outlined in any of the above texts or use a turbo calculator software to determine your engines airflow requirements so that this data can be plotted out on a compressor map for verification.
With the influx of cheap Chinese turbos, it is common for someone to want to buy these as a basis for their system. While some have had decent results with them, it seems terribly hit or miss. Their specs are also seemingly very incorrect and misleading which is one more reason not to buy one.
Stay away from most “junkyard” turbos as they are typically way to small for either the M20 or M30. Most 80s vintage turbo cars were small trim t3 turbos and their compressors are way to small to support good power on either engine. Also the turbine housings will prove to be very restrictive limiting power.
A quality Garrett T04E (there are various trims available depending on desired power output) makes an excellent turbo for the M20 and M30. These can be had new for under $700 with your own specs. Garrett also offers a large variety of ball bearing units that are well suited to both engines.
There are a fair number of both m20 and m30 powered cars using Holset turbos with good results. These are typically found of Dodge Cummins powered trucks. There are several versions offered over the different model years. They are quality OE turbos but since compressor maps are scarce, your best resources are other Holset users.
Do I need an intercooler?
No, an intercooler is not required for low boost setups (10psi or less). Both air to air (A-A) and water to air (W-A) intecoolers can be used. TCD stage 2 kits come with a water to air unit. Cartech also offered an air to water unit that was integrated into the intake manifold. These are sometimes available used. All water to air units require the use of a pump, reservoir and additional front mounted heat exchanger for operation. They work very well and package nicely but add expense and an additional level of complexity to the system. A-A units are much simple in concept but typically require moderate to extreme sheet metal modification as well as more complex piping.
Where do I find a turbo back exhaust for my car?
At the time of this writing the only supplier for a pre-made turbo-specific exhaust for the e28 is TCD and is designed to work with their kit. However, any high performance e28 exhaust can be used however but may require modifications. Generally most use a single 3” diameter exhaust from the downpipe back.
A custom exhaust can also be fabricated using the muffler and high flow catalyst (we all know that you want to do the responsible thing ;) ) of your choice and roll your own. Use mandrel bent pipe to minimize restriction. There are many places online where you can purchase a variety of bends in mild steel and stainless.
How do I supply oil to my turbo?
Since all turbos, journal or ball bearing, require a clean, filtered oil supply from the engine. There are a few methods to accomplish the oil supply and drain. Oil can be tapped from the oil pressure sender location on both the m20 and the m30. These are in different locations on each engine, but both require a male 12mmx1.5 pitch to thread into either the block (m20) or the head (m30). You will want this to adapt to either an NPT or AN fitting so that an oil line can be routed to the turbo. A Braided -4AN line works well in this application. Some ball bearing turbos require an oil restrictor so confirm this with the turbo manufacturer.
The second method for the m30 is to drill and tap the oil filter housing so that an adapter fitting can be threaded in to the housing for attachment of the oil line. Shawn D.’s site outlines the procedure for drilling and tapping your housing.
The turbo drain is a critical part of the oil supply equation. If either the supply or return fails, your engine pumps out all of its oil potentially damaging your engine. It could also lead to an oil fire. Most people drill and tap the oil pan. This can be done with the oil pan in place. The recommended size for the fitting is ½ NPT, which requires a 45/64” drill. An image of a mounted drain from my car is linked here.
Turbo Oil Drain
If you use rubber hose, make sure it is rated for oil and is capable of withstanding over 300ºF, as the oil will be hot exiting the turbo and it lives below the exhaust.
As a general word of advice – do NOT skimp on the oil supply and return system.
What do I need to build my own system?
The core components needed are shown below. This is bare minimum to make the car work. This should allow you to have a low boost setup capable of 5-7psi
• Turbo
• Manifold or adapter
• Wastegate (unless using turbo with internal gate)
• Charge pipes
• Couplers – rubber is cheapest
• Clamps
• Oil feed and return
• Downpipe
• FMU
What is recommended:
• Intercooler (water-to-air or air-to-air)
• Fuel Pump
• Silicone Couplers
• Quality T-bolt clamps
• Boost controller
• Larger fuel injectors (30+lb/hr)
• Chip for stock DME or Full Standalone
What do I do for fuel management?
All turbo cars require some sort of fuel enrichment. Without it you will make melted paperweights that make good conversation pieces. The bare minimum here is a Fuel Management Unit or FMU. It is my opinion that the BEGi/Cartech units are the best on the market. The BEGi 2025 works well and can be found at
http://www.bellengineering.net/index.php
The FMU causes a boost dependent rise in fuel pressure to force addition fuel through the injectors. This coupled with larger than stock injectors, an adjusted air flow meter (AFM) and a turbo chip (used for ignition timing retard) should safely allow 12-13 psi. An upgraded fuel pump is highly recommended when using an FMU as the dramatic increase in fuel pressure can tax the stock fuel pump
While the above solution will work well, many want the ultimate in control. Enter standalone engine management. While there are many brands of aftermarket standalones, it seems the most popular is the DIY unit Megasquirt. There are a good number of well tuned, fast turbo e28s using Megasquirt so there is an established community that is typically very willing to help out new users.
http://www.megasquirt.info/
What size fuel injectors do I use?
Typically you will want to upgrade the injectors to a minimum of 24lb/hr when using an FMU. 30lb/hr is a very common injector size when using an FMU. RC Engineering has a simple calculator that will help you select an injector to suit your desired power level. For all M30 powered cars using the stock DME you will want to purchase high impedence, or saturated injectors. These typically have a coil resistance of 11-13 ohms. The use of low impedence, or peak and hold injectors will sink too much current from the stock injector dirvers and burn them out. High impedence injectors can be substituted for low, just not the other way around. Using high impedence injectors also makes the tuning of a standalone easier. The downside of high imp. injectors is that when they are very large (say over 72lb/hr) they can be very difficult to tune at very low pulse widths thus making idle tuning difficult.
Do I have to upgrade my fuel pump?
The short answer is no. The stock Bosch pump in good shape should be sufficient to supply fuel to a low boost setup. I say this with reservations however, as a fuel pump that cannot supply enough fuel will cause you to run lean and potentially kill your engine. Most stock pumps are at best 20 years old and things that get old aren’t what they were when they were new. A Walbro 225lph pump or a TRE Performance 255LPH pump easily replace the in-tank pump and will support well over 400whp. For around $100 it seems almost a no-brainer.
What spark plugs should I use?
It is recommended that when turbocharging that you drop two to three heat ranges on your plugs. NGK and Denso make plugs which work well in turbo applications. I run
NGK BPR7ES which well and are 2 ranges colder than stock. BPR8ES also work well and are 3 ranges colder than stock and work well for higher boost levels. NGK’s numbering system has the heat range decreasing (ie – colder) as the number increases, so the 8 is colder than the 7 (stock is a 5). I gap mine to 0.028” and have no problems with spark blowout. Also keep in mind that heat ranges between brands may not correlate directly.
I have more information forthcoming and will update this FAQ accordingly.
Enjoy!!
Posted: Jul 10, 2008 2:22 AM
This is an excellent idea, and a great starting point for people that are considering turbocharging. It's like answers to the most common questions all rolled into one post! What a concept!
It is well-written, as well! :up:
Posted: Jul 10, 2008 2:35 AM
by Jays535is
Great write up! :clap: This should be stickied ASAP.
Posted: Jul 10, 2008 11:40 AM
by George
Well done.
Posted: Jul 12, 2008 2:46 PM
by underwatervans
amazing write up
Posted: Jul 12, 2008 3:02 PM
by Duke
Posted: Jul 12, 2008 3:23 PM
by Jeremy
Duke wrote:You make reference to TCD eight times. Are they still in business?
Despite your best efforts. Yes.
Posted: Jul 12, 2008 3:26 PM
by Brad D.
I have no idea if they are still in business. I would guess so but don't know that for a fact. I have never delt with them, but only listed them from a neutral point of view as a seller of kits and citing information. It was in no way an ad for TCD.
Posted: Jul 12, 2008 4:00 PM
by alijonny
awesome!
Posted: Jul 12, 2008 4:11 PM
by Duke
Posted: Jul 12, 2008 5:12 PM
by stevgtguy
Great write-up indeed as I am planning on venturing to the dark side after I get my e to i swap completed. I can tell Shawn D has not read this post yet as there are a few corrections needed. ;) :laugh:
Posted: Jul 12, 2008 5:38 PM
by Jeremy
Touchy? Not really. The simple fact is, TCD is one of only a few companies I'm aware of that's selling new condition parts to turbocharge an m30 engine. Thus, they'll be prominent in a FAQ about turbocharging said engine. You may not like it, and I'm well aware of why you don't, but that's the way it is.
As far as the FAQ itself goes. A non-intercooled turbo on an m30b34 can safely go to 12-13psi easily. At 10 psi, I can run 89 octane fuel in the summer with no audible detonation. 15psi is the hairy edge for stock compression, M1.0A engine management with stock timing, and 93 octane without intercooling.
Also, you may want to include manifolds that've been made in the past that people may come across used. This would include the 745i manifold that you mentioned, but also includes Cartech, Dinan, Alpina, and a few others whose names escape me at the moment. Cartech also made water-air intercooler units that can be found used every once in a while.
If you limit the FAQ to only stuff available new, you may as well just include a link to TCD and 666fab. You opened the door with the 745i info, so I figure it's probably a good idea to include as much information about the older stuff as possible.
Posted: Jul 12, 2008 7:21 PM
by Shawn D.
stevgtguy wrote:I can tell Shawn D has not read this post yet as there are a few corrections needed. ;) :laugh:
Dude, there are only so many minutes in a day... :laugh:
Posted: Jul 12, 2008 7:27 PM
by stevgtguy
:rofl: :rofl: :rofl:
Thanks I needed that. I figured that would get a response out of you. ;)
Posted: Jul 12, 2008 8:31 PM
by Brad D.
I am slowly adding to and correcting this FAQ. I just made some updates. I added a bit of info as well as corrected some the spelling and grammar errors made while hastily throwing it together. ;) More to come.
Posted: Jul 14, 2008 9:58 AM
by vance
Brad, thanks for taking the time to put this together.
Vance
Posted: Aug 14, 2008 12:44 PM
by babisbabou
BBR respect ;)
Posted: Aug 14, 2008 1:37 PM
by ldsbeaker
Thanks!!
p.s. I'm glad that I have the right books to read. Asking people about turbo theory is such a PITA.
Posted: Aug 14, 2008 2:13 PM
by tsmall07
:shock:
This is amazing. Exactly what I need.
I, for one, would like to see this stay as an open sticky in this forum instead of moving it to the general FAQ. This could be a running FAQ where the new guys can come to ask questions without feeling nervous about bothering the guys that know what they're talking about. Thats why I haven't participated in this section very much.
Posted: Aug 22, 2008 1:34 AM
by DaRedRocket
Just saw this after being away from the boards for a couple of weeks and what an idea. :up:
Posted: Oct 10, 2008 11:17 PM
by alijonny
So what is the general consensus on the TCD turbos themselves? who is the manufacturer? anybody with info would be much appreciated.
Posted: Oct 10, 2008 11:20 PM
alijonny wrote:So what is the general consensus on the TCD turbos themselves? who is the manufacturer? anybody with info would be much appreciated.
I assume the "Stage 1 Turbo" will correspond to the "Stage 1 Kit"
http://www.turbochargingdynamics.com/pr ... _Turbo.php
Posted: Oct 10, 2008 11:32 PM
by alijonny
:? maybe I typed something wrong...
ok, so how about the actual turbo
let's say I wanted to purchase just the turbo, as advertised, on TCD's website. what is the quality of said turbo? cheap knockoff status or a decent built unit with no epoxy in site?
Posted: Oct 10, 2008 11:39 PM
alijonny wrote::? maybe I typed something wrong...
I got what you said. The link I gave was for just the turbo. I was just saying that the turbo they list as the Stage 1 Turbo is probably what's supplied in the Stage 1 kit. ;)
Posted: Oct 10, 2008 11:41 PM
by alijonny
well, I asked for input, and input is what I got... I guess. thanks. :roll: :lol:
Posted: Oct 11, 2008 12:15 AM
by Brad D.
The turbos are Garretts. They use on-center tubine housings. I believe the typical AR on the hot side is a .63. The compressor is a T04E, but I am not sure exactly what trim. I know it's been posted before but my guess is it's around a 57 trim to a 60 trim(pretty sure it's a 60) compressor wheel. I know some also use a GT35 comp wheel. A bit of compressor map matching should help out here.
Posted: Oct 11, 2008 11:36 AM
by Jeremy
TCD sells real Garrett units, not imitation knockoffs.
Posted: Nov 03, 2008 3:50 AM
by jbd5015
this is probably covered in the books you recommended reading, but for those (like me) who dont have them, i found out a good website about turbo charging basics. Its actually the garrett website. Its their whole 'turbo tech' section in the link below.
http://www.turbobygarrett.com/turbobyga ... enter.html
It answered a lot of my basics questions, and is definitely worth a flip through! I understand everything in the 101 and 102 turbo tech sections, but one thing im still confused about is the T04E. Does this have something to do with the housing size? And this has nothing to do with the T3 and T4 mounting patterns correct?
Thanks guys! Doing all the reading i can so ill be able to have a decent conversation at some point haha!
-Jeff
Posted: Nov 03, 2008 11:18 AM
by turbodan
Skip straight to the turbo tech 103 section. Thats where you get into the meat and potatoes of things. 101 and 102 cover basics like housing A/R and wheel trims, but 103 is the important stuff.
T04E compressors are part of the T4 compressor family. The T04E designation refers to the compressor housing. Common T04E turbos are the 40 trim, 50 trim, 57 and 60 trim. Other T04 compressors are the T04B and T04S families. The housing selection isn't as important as the wheel selection though. The best way to go about that is to start plotting your engine on various compression maps until you find the best fit.
T series stuff works, but it is a little out of date. I like spending lots of money, so I use Garrett GT series turbos. The dual ceramic ball bearing center sections are indestructible and they're much more responsive than journal bearings.
Posted: Nov 03, 2008 11:20 AM
by Brad D.
T04 refers to the family of compressor wheels. The 'E' refers to the specific cover, or compressor housing, that is on the unit.
Edit - Dan beat me to the punch.
