bleeding M5 cooling system
Devinder
Post by Devinder »
What is the best way to bleed the cooling system? There is no bleed screw but the thermostat housing is vented to the expansion tank. My first thought is to let it self-bleed with the cap off.
monty23psk
Post by monty23psk »
the m5 is self bleeding. There is a small hose out of the expansion tank under neithe the cap. just make you you have enought coolant in the system with the correct mixture. one painless and great things our cars have.
alex in s. fl.
88 m5
04 civic
Devinder
Post by Devinder »
Thanks Alex -- maybe I should convert my M30 to self-bleeding too
