Does MyE28.com know everything?
It may be the marinated asparagus and London Broil done to perfection talking but I think this website could answer any query posed. This brain trust is phenomenal!
booker
Post by booker »
Yes.
Why do you ask?
Why won't my 22re idle? I've seafoamed the tank/vacuum lines, set the timing, cleaned out the throttlebody (haven't actually removed it, but sprayed it w/carb cleaner, wiped with rag, even did a seafoam spray clean), it keeps dieing. When its cold, it idles, when I'm coasting at speed it idles, when I brake to a stop-dies.
It actually idled for two weeks (just started driving it) then all of a sudden quit the other night.
Go for it! :D
Dang near.
djazz
Post by djazz »
cddallara wrote:Why won't my 22re idle? I've seafoamed the tank/vacuum lines, set the timing, cleaned out the throttlebody (haven't actually removed it, but sprayed it w/carb cleaner, wiped with rag, even did a seafoam spray clean), it keeps dieing. When its cold, it idles, when I'm coasting at speed it idles, when I brake to a stop-dies.
Go for it! :D
What I don't know I can usually find. HTH:
TPS?
Did you adjust the idle when warm?
Are all vac lines connected correctly and clear? (edit: Well, you seafoamed them. nm)
Sounds like a pretty common problem. See:
http://forum.ih8mud.com/79-95-toyota-tr ... oblem.html
alijonny
Post by alijonny »
understanding women. Shall I ask?
freetoride
Post by freetoride »
Do you have a vacuum gauge? Brake booster good?
djazz
Post by djazz »
freetoride wrote:Do you have a vacuum gauge? Brake booster good?
Are you responding to the 22re problem or the understanding women problem? :D
Bimmerguy2002
Post by Bimmerguy2002 »
alijonny wrote:understanding women. Shall I ask?
PM BMWgiant for all women advice inquiries.
Go for it! :D
TPS?
I get conflicting reports on the TPS. It has been replaced by aftermarket :(. Some people say it won't affect idle, except to make it stutter sometimes, not quit altogether. Coolant temp sensors were also mentioned.
No CEL though.
I'll read the thread and see if I can work on it tomorrow, and report beck.
If the TPS is set in such a way that the car doesn't know the throttle is closed, and it thinks the throttle is still open, it's going to die. I used to get this in my 535is when the AC was on. I'd come to a stop and the car would die. Turned out that the TPS was out of adjustment - I don't know how it actually happens aside from using big slots and screws, perhaps it moves over time. That said, readjusting it so it would click when the plate was actually closed fixed the issue.
Post by C.R. Krieger »
Go for it! :D
'Dying'. :tsk:
Go for it! :D
'Dying'. :tsk:
Thanks, I don't know how, but a always mess that one up. :oops:
Checked vacuum line routing and tried to mess with TPS even though I know I need one of those short right angled screwdrivers.
I guess the next step is pull the TB off, and clean it super good. And replace my Taiwanese TPS.
nik77356
Post by nik77356 »
I think MyE28 needs a Toyota sub-forum. ;)
Go for it! :D
I don't know anything about that, but I do know that while "dieing" is grammatically correct, it is not the correct reference. You need to use the spelling "dying".
The more you know! http://dieingordying.org/ :banana: :alright:
Re: Does MyE28.com know everything?
oldskool wrote:It may be the marinated asparagus and London Broil done to perfection talking but I think this website could answer any query posed. This brain trust is phenomenal!
While the resources here are impressive, I'm guessing it was more the Cabernet that accompanied the asparagus and London Broil that was doing the talking. :laugh:
Nicke28
Post by Nicke28 »
nik77356 wrote:I think MyE28 needs a Toyota sub-forum. ;)
and a Volvo turbobrick sub-forum. :lol: Volvo forums tend to be boring. ;)
One day I plan on owning a Lotus Europa, Porsche 930 turbo and 928. I think we should consider sub forums for each of those cars too. :rofl:
alijonny
Post by alijonny »
nik77356
Post by nik77356 »
How about we just cover all the bases at once and have a sub-forum sub-forum?
Nicke28
Post by Nicke28 »
I'm starting to rethink this after tonight, as certain mye28 members like to spread rumors to cute waitresses that I'm gay! :brickwall:
djazz
Post by djazz »
Now I just can't see them spreading rumors like that.
But so the Beamters know, just how sub- do you want your sub-forum?
:shock: Wrong thread. :oops:
Nicke28 wrote:I'm starting to rethink this after tonight, as certain mye28 members like to spread rumors to cute waitresses that I'm gay! :brickwall:
Nobody said gay. The word used was "married". :laugh:
Brian in TN
Post by Brian in TN »
:rofl:
Let's put a subforum about having subforums so other people can post in that subforum's subforum about subforums.
Ken H.
Post by Ken H. »
Does mye28.com know everything?
No, but the participants hereon think they do. :bs:
Ken H. wrote:Does mye28.com know everything?
Hey, if Google knows it ... we know it. ;)
nik77356
Post by nik77356 »
shagrath wrote::rofl:
I think we have a winner! :laugh:
You should let everyone know. ;)
nik77356
Post by nik77356 »
If MyE28 knows what the square root of an elephant is, then it officially knows everything.
