Poll: HP Contest!
Ahem... Maybe my our turbo 6er will be up there in the Hp #'s, its already close to the top of the list with broken parts. So far we are on our 2nd intercooler, 2nd turbo, 3rd blow off valve, 2nd clutch, and thats with it being driven only about 60 miles. Who else here is over 400 wheel hp at the moment?
Justin
Justin
Duke, TCD, all others....you'll be IN FOR IT when I paint my calipers yellow and put on my spoiler! Those upgrades, in addition to the stickers I've already purchased on ebay, will put me towards the 600-625 hp range minimum. Let's not even talk about drag racing-the 6" muffler will make you cry before we even get to the starting line!!
In all seriousness, it looks like Duke's car has a very good chance of #1. Although 27lbs of boost is quite a lot, couldn't Duke raise his boost as well, although temporarily, for a dyno run? He wouldn't necessarily have to keep the car in the usual street setup, unless that's what you agreed to beforehand. Just a thought.
[QUOTE="BMWJustin"]Ahem... Maybe my our turbo 6er will be up there in the Hp #'s, its already close to the top of the list with broken parts. So far we are on our 2nd intercooler, 2nd turbo, 3rd blow off valve, 2nd clutch, and thats with it being driven only about 60 miles. Who else here is over 400 wheel hp at the moment?
Justin[/QUOTE]
Geez, who is choosing the parts for that car? Hope you are not paying for the education!
Todd
Justin[/QUOTE]
Todd
[QUOTE="Yellow"]i wont reveal my turbo secrets for my e28 :p just wait a few months and then we will talk. im pretty sure that in a few months therer will be quite a few new turbos running around with some numbers.
tcd- what is your price on a water-air IC setup? i would be interested in one. [/QUOTE]
$1525
Thanks,
Todd
$1525
Thanks,
Todd
[QUOTE="TCD"]Let's hear who you think will make more HP by the end of the year 2005.
ChrisM
TCD
Sweeney
Second poll:
Who will break the most parts?
Anyone lurkers out there that plan to blow us all away? I know of one S38 Turbo that thinks so. Any others? Mostly just refering to board members.
Todd[/QUOTE]
Knowing what I know about various projects, I think it'll shake out like this.
HP:
Duke (with that head plus TEC3 plus high psi will be tough to match)
TCD
Sweeney
Chris M (c'mon, chris, put that damn thing back together, will you??)
Broken parts:
Duke (with that head plus TEC3 plus high psi I think he'll break about every driveline component imaginable at one point or another)
Chris M (the king of the shattered piston, note that this only applies if he actually gets his 5 cyl wonder running again . . . )
TCD (already broken a bunch of stuff, so his car is pretty well sorted and strengthened)
Sweeney (reiforces before stuff breaks, not after, and doesn't tell many people when it does break (which I would imagine is quite rare), so even if he doesn't have the fewest failures, he'll definitely have the fewest people know about it, lol)
ChrisM
TCD
Sweeney
Second poll:
Todd[/QUOTE]
HP:
TCD
Sweeney
Broken parts:
[QUOTE="bmwbimmer"]I know what you mean RDAvena the first time I was in a turbocharged BMW was when my buddy jason had a 1986 528i that was turbocharged and that car was so fast and it pulled so hard If I remember right that car was running 20 or 24 lbs. of boost let me tell you it was a kick to drive. Untill the head gave up the rotor came loose and spun in the cap. Thats when we decided to turbo a m30 3.5 liter and we where going to us the old CAR TEC kit untill we meat Todd and joson bought one of his turbo kits its going to be a real kick in the pants we are going to try for 20 to 24 lbs of boost later on down the road after we work out all the bugs.[/QUOTE]
Damn, dude. And on the 8th day, God invented punctuation.
I recommend picking up a copy of Strunk and White's "Elements of Style." It'll be a well-spent $5 or so.
-tammer <--feeling grammar-nannyish today, sorry
Todd;
Many thanks for resurrecting this forum...lots of good exchange here.
It's been an long road getting this motor running right. Yes, I too have suffered the loss of pistons collapsing under the pressure of detonation. Even with Electromotive controlling fuel/timing, things break when you push too hard. Just a word to the wise...
Right now I'm laying low due to some job setbacks, but the car pulled a respectable 330 hp a few weeks back at around 12-13 psi. I know the GT-35/40 can push mid-twenties with a fair amount of efficiency, but I just can't risk a meltdown right now. Programming is still weak, running a bit fat with starting/idle issues to iron out. I think there are still some bottle necks in the intake plumbing, notably the throttle body, so getting better flow at the lower boost pressures is my goal right now. I think 100 rwhp/liter is doable at less that 15 psi. Short -term: around 380 hp for the for the bored M-30 at less than 1 bar.
Alpina used the 745 head with bigger valves (I think.) New pistons were made for a mid-eight compression ratio.
The jewel of the setup is the custom exhaust mainfold, really. Somewhere, awhile back I read an tech article on the concept of something I think was called "positive cross-over." Anyway, it talked about how, through the use of a tuned, equal length header-style exhaust manifold, builders could achieve intake pressures in excess of exhaust pressures. Yea, try to get your head around that one. Long story short, the car went down for a year while a 204SS header was built. The GT was fitted, Tial wastegate, 3 in. exhaust and a recently upgraded Spearco A/A heat sink added.
Once things settle down with the finances, I'm looking forward to throwing the car around a bit at Willow Springs, a track about a half hour from the house. Should be fun.
Take care,
Jim
Take care,
Jim
[QUOTE="alpinajim"]Todd;
Take care,
Jim[/QUOTE]
Jim,
How about some pictures?
Todd
Take care,
Jim[/QUOTE]
Jim,
Todd
I would not count me out of this race I am already over 300 rwhp at 10psi none inner cooled running a little rich and stock plugs. I am going to try hard to hit 400 rwhp at 15psi and that is with the stock engine management with the TCD chip.
Before the year is over I will be pushing 400-500rwhp
[Edit by bmw335is turbo on [TIME]1113623050[/TIME]]
Hey all, I'm a new poster to this forum. I have an e28 m5. I just pulled my s38 and i have a fresh dinan turbo m88 waiting to go in. I'm waiting on a couple parts from Jim at Autobahn and some aluminized firewall heat protection I ordered. The motor is rated at 468hp @ 12.5 psi. I'm running the split second MAF sensor conversion so i should make even a little more power. I think im going to limit boost to 15psi. I'll eventually be running a MAP sensor, water injection, and a more efficient intercooler setup so i should be up in the runnings for this HP Contest. Should be a runner in the next month or so.
I've been following this thread, I have been thinking Duke would be the leader, but now that Ken H has released details about "Lucifers Hammer" I'd say he will be the hands down winner for big hp with Duke coming in second!
I know first post and all but I've been lurking for years...........where the hell is Shifty Anyway?
I wonder if Zane Coker, our E12-torch-carrier will ever get involved in this turbo circle? He's pretty modest, but he told me recently the car is putting out about 800 at the crank. Problem is he can rarely use it because of the footprint of the rear tires. And he said he can feel it twist the body "like a rag". I'd like to have seen him bring it to 5er Fest and show the car off. Maybe if I come to the 2006 5er Fest (I'm setting a goal for myself dammit!) I can haze him into coming.
I never did get a ride in the damn thing when I did that Roundel article since it was frickin' raining!
Adam Wilson
www.e12m535i.com
Feel free to scroll through this directory of pics I took when I did the article.
Adam Wilson
www.e12m535i.com
http://www.e12m535i.com/BMW_E12/images/Zane_Roundel/
Adam Wilson
www.e12m535i.com
I think he had the turbo reworked (again) by some guys that build Buick Grand National turbos. He said it is noticably stronger and he guessed it might be pushing 800 at the crank. The dyno graph I saw where it did 650 at the wheels according to Zane was done in the neighborhood of 28psi of boost. He doesn't normally run that around the street since 12 pounds will blow almost anything away.
He has new wheels and tires on the car in an effort to get a bigger footprint under it. I think the rears are 245's now, which is still tiny compared to the power output.
Zane's also moonlighting as a advisor/mechanic for a local Toyota Supra race team so I'm sure he's honing his skills even further there using their parts budget. I think the car they race runs in the 8 or 9 second range and is a 1500hp, methanol, turbo Toyota inline 6. I don't know all the details though, that's what I remember from Zane's latest update email.
Zane's also helping a friend out by building a milder turbo M30 in the guy's 635.
Adam Wilson
www.e12m535i.com
Adam Wilson
www.e12m535i.com
I just went to Zane's site and he posted an update in April on his message board with some dyno stats. I was wrong, it wasn't 800 horse, but he's getting close. Here's what he wrote up:
Many people have asked me about the strength of the M30 engine platform, or what it is capable of, or its maximum allowable power level. There are not too many out there who have tested these engines into the huge power/boost territory. Most of what Ive seen are estimations with no other vital supporting engine data. Here is an actual 32bit (200bits per second) data-log which shows the BMW M30 (or M90) at its' best:
BOOST.................32psi(sustained)
RPM...................5492 (8000 max)
Intake Temp...........117.6 F
Timing................15.3 degrees
AFR (Wide Band).......11.0
Throttle (TPS)........66%
Power at this run: 723BHP/692ft/lbs Torque
As most will note, the most common engine parameters are not stressed at all---there is plenty more to go! Impressive is the relaxed state of the data at such a high boost level. This data run was on 110 octane fuel with water/meth injection. Had to stop due to smoking tires at such high power/speeds :o)
His website is:
http://home.att.net/~Nastroma/blacky.html
Adam Wilson
www.e12m535i.com
His website is:
Adam Wilson
www.e12m535i.com
todd im sure you have it wrapped up. dukes engine sounds nice as a nat/asp. but all the intake/ head work will not make up for boost. there is a reason that turbos are not allowed in f1 (remember the 80's 2.0L turbos 1200-1500hp!). maybe duke can spin that thing to 1200rpm (would get the prize for broken parts for sure) ~0
i hope have the little red one running soon. the first step will require the boost limit remove chip and adj fuel press reg. can you help on these?
[QUOTE="Adam Wilson in Chicago"]I just went to Zane's site and he posted an update in April on his message board with some dyno stats. I was wrong, it wasn't 800 horse, but he's getting close. Here's what he wrote up:
His website is:
Adam Wilson
www.e12m535i.com[/QUOTE]
Man, I was reading all this stuff, and I though that was Blackie. I see hes got it running and tuned. Very nice.
Check that info on F1 turbo engines, it's 1400hp from 1.4l displacement
His website is:
Adam Wilson
