OK, I have the test results from the WOT/AFM ignored tests..
russc
Post by russc »
I'm a blundering ignoramous....
The AFM is not ignored during WOT %) %) %) %) %) %) %) %) %) %)
Im not so proud I can't admit it, I was wrong. And this so weid, I had this conversation with SteveD face to face on this, maybe I was baffled by bullshit, I'm not sure, but the proof was definatley in the pudding.
But, I discovered yet another function of the DME, it's intelligence never stops astounding me. If I set the SAFC-II to a crazy AFM out, the ECU is smart enough to know theres something amiss and it goes into a fail safe mode so the car wont completely flood out from fuel and stall. It knows the range the AFM input should be for a given RPM and throttle input, and if it's outside this range, it will start what feels like a rev limit and pulses fuel on and off at the point the AFM goes whack, so it wont flood out ~0 ~0 ~0 ~0
This is very nice, I was not aware it would do this. Again, there is some very nice intelligence built into the software on these DMEs, way more than I would have thought, and a very large adaptive range on injs.
Thank you very much for doing the legwork to settle this, Russ. I wouldn't even know how to get definite proof one way or another.
[QUOTE="russc"]I'm a blundering ignoramous....[/QUOTE]
Ahh, that's ok, we tolerate all kinds (well, most kinds anyway). We'll just go back to our usual business now. Y'know, like making fun of your archaic turbo Dinan system. ;)
Guest
Post by Guest »
Russ' Dinan turbo might be archaic, but it has something that NO newer turbo setup I'm aware of has.
Approval from the the California Air Resources Board.
Rich
LOL, Rich. Yep, that's true. But I can't I yank his chain? Just a little? :D
russc
Post by russc »
[QUOTE="Rich Euro M5"]Russ' Dinan turbo might be archaic, but it has something that NO newer turbo setup I'm aware of has.
Rich[/QUOTE]
Yep, 50 state legal.
As for archaic, Mmmm...this system isn't any worse than the kit that TCD sells. The better points on TCDs stuff is just a newer turbo with updated inner wheels. But on the FMU front, the Turbotrinics box does the same electricaly, so there equivalent there. And, as far as I can tell, Todd still hasn't beat my dyno #'s ~0 ~0 ~0 ~0 ~0 ~0 ~0 ~0, and I'm using crappy CA gas.
I know Todd, but every time you go to make one of those 20psi runs, the car seems to not work or is broke ;) Actually, what HP does you 1/4m run indiacte??
scottiesharpe
Post by scottiesharpe »
Russ, on the flip side of the coin, DME also protects against lean condition (AFM signal out of logical range) and will flip you into load-limited protection mode for 4-6 minutes, or until the situation is corrected.
russc
Post by russc »
[QUOTE="scottiesharpe"]Russ, on the flip side of the coin, DME also protects against lean condition (AFM signal out of logical range) and will flip you into load-limited protection mode for 4-6 minutes, or until the situation is corrected. [/QUOTE]
Yup, thats probably what I felt.
