What gear can you Break tires....
rundatrack
Post by rundatrack »
Not a chirp like us Stock gentlemen..but when you get a
~0 ~0 ~0 ~0 ~0
From the passenger...or the first time you did it and spoiled ya draws...
Just thinking of the power some of you guys make
Jeeehellll....lusssss...
:D
gol10dr1
Post by gol10dr1 »
i can spin first but thats about it considering my tranny is about to shit the bed. i loose all momentum between gears. but i did break em loose at the TOP of second the other day!
1st I can light up almost at will, 2nd will spin half the gear if I shift hard from first at the rev limiter. Third is just a quick chirp and bite.
EDIT: Well, if we're talking one night occurences like TJ, I once shifted hard to second getting on a long highway on ramp and couldn't understand why the revs didn't drop like usual, they stayed right around 5500rpm. I stayed on it and all of a sudden the revs jumped to the rev limiter, so I shifted hard to third. Revs stayed high again for a few seconds seconds before coming gradually down to where they should've been before climbing normally. I realized after that I had just spun almost all of second and most of third gear. Not spun hard since I was still accelerating very quickly, but enough that the revs didn't match the speed. This was on a nice cool night night (50 degrees or so) and the car still running way fat.
[Edit by Jeremy on [TIME]1127511094[/TIME]]
Tjn182
Post by Tjn182 »
i've busted 2nd loose on a nice cool night at the beach - @ 4500rpms at about 45-50ish mph - it wasn't just a little, the whole backend squirrelled around and spun the tires fully until redline.
edit: just busted second gear loose again last night - this time I was going about 50mph
[Edit by Tjn182 on [TIME]1127670226[/TIME]]
Boru
Post by Boru »
I've broken them loose in 3rd, around 55-60 mph. At lot depends on your tires, road conditions, camber/contact patch. Given all the variables, I can break the tires loose on my Jeep in 5th gear ;)
papajetta
Post by papajetta »
on rainy night i redlined 5th, i'll never try that trick again, car stunk like gear oil for weeks
greek88
Post by greek88 »
my tires stick .... which is a good thing, right? but smoking your tires is always fun, i'm a fan of drifting... and powerbraking, especially in an 80s volvo station wagon
[Edit by greek88 on [TIME]1132322188[/TIME]]
Jesse
Post by Jesse »
I got it all out of shape in second gear last week on a nice cool morning after correcting my timing (my distributor had come loose and rotated). I had been wondering why it just didn't seem as fast for a while, then I found the loose distributor (duh).
As long as my little A-A intercooler is not heat soaked, I can break them free at will in second now :cool: .
greek88
Post by greek88 »
i got all the way through first and second today. but the ground was wet. i can't break em loose on dry ground, except from first to second, i can chirp em for about a full second if i really try
bmwfan2304
Post by bmwfan2304 »
when i had stock tires and everything i once broke my tires lose going into 3rd... then my back end swung out to the side and scared me half to death. but my car isn't turboed yet! :( so not the same thing...
