Hi. I'm Marshall.
I go to school in California from mid-September until June. While I'm not there, I'm at home in Marietta, GA, working on an '85 635CSi.
Since I have to leave my shark to the care of my family while I'm at school, I really want to make the most of the time I have here. So I have a hell of a lot of project planned for the next few weeks.
Problems:
- Overheating tendencies
- Awful rough idle
- Awful 55+ mph shimmy
- Stock ride height
- Cracked steering box mount
- Zip-tied aux fan
- General engine bay grossness
- Automatic transmission
- Bent valance bracket
- US bumpers
- Stock exhaust
- Stock US M30B34
- Sketchy RC090s
- Cooling system refresh
- Fix the rough idle
- Relatively stock top end rebuild (mostly for my own peace of mind)
- A drop
- New front suspension
- Custom aux fan mount
- Fix valance bracket
- Perfect sound system - there's a little alternator whine at the moment
- Clean up the wheels
- Headers + hi-flow cats
pixxxx:
(only a few for the moment)
2012-07-09 18.23.02
2012-07-09 18.23.11
...and now my M30 is sitting on my garage floor.
The plan for the moment is to go ahead and get head/valves done at a machine shop, do a stock-ish rebuild of the top and bottom ends, fix the wealth of vacuum and electrical issues I had, clean it all up, and drop it back in with new headers. I'm relatively mechanically inclined, but not very experienced with this sort of thing. I have a friend helping me out that knows much better what he's doing, but I definitely would like all the help I can get.
More pictures:
2012-07-09 18.23.18
2012-07-09 18.26.33
2012-07-09 18.26.45
^ in pulling the motor we smacked the front against the front bit of the radiator and scraped off a little paint. whoops.
I'll be following the Bentley manual for most of the rebuild stuff. Please point me toward any information or helpful links!
more pics:
the complete disaster that is my garage:
2012-07-10 23.59.20
one of the awful sensors that probably caused a few issues...
2012-07-10 23.57.27 by seewhereweland, on Flickr
we dropped the pan to get a socket on the torque converter mounting bolts. I think we did this wrong: took the transmission off without taking the torque converter with it. thoughts?
2012-07-10 23.59.02 by seewhereweland, on Flickr
grimy, nasty, disgusting block and pulleys.
2012-07-10 23.56.46 by seewhereweland, on Flickr
valve cover off!
2012-07-10 23.55.20 by seewhereweland, on Flickr
block's a bit rusty...
2012-07-10 23.55.06 by seewhereweland, on Flickr
intake side
2012-07-10 23.54.56 by seewhereweland, on Flickr
and finally, the reason my M30's run like shit for as long as I've owned it...
2012-07-11 00.46.13 by seewhereweland, on Flickr
2012-07-11 00.47.30 by seewhereweland, on Flickr
2012-07-11 00.47.40 by seewhereweland, on Flickr
2012-07-11 00.47.48 by seewhereweland, on Flickr
2012-07-11 00.48.25 by seewhereweland, on Flickr
2012-07-11 01.00.25 by seewhereweland, on Flickr
the head's off to a head shop in Marietta, I still have to get the block sandblasted, various parts powder coated, and bottom end rebuilt. many late nights await.
Not really going for a performance build, both since this is my first rebuild and I'm trying not to spend more money than I have.
Properly mounted it up to the engine stand last night. Took the oil pump, flywheel, and one of the pistons out. Here are some pictures...
2012-07-17 01.21.37 by seewhereweland, on Flickr
the crank!
2012-07-17 01.22.17 by seewhereweland, on Flickr
the one piston we took out so far. this is after cleaning it up with a nylon brush & brake cleaner:
2012-07-17 01.22.26 by seewhereweland, on Flickr
check out that piston wear!
2012-07-17 01.23.38 by seewhereweland, on Flickr
the gunk is baked on pretty thick:
2012-07-17 01.23.03 by seewhereweland, on Flickr
flywheel:
2012-07-17 01.24.18 by seewhereweland, on Flickr
bearing:
2012-07-17 01.23.27 by seewhereweland, on Flickr
my sad, sad radiator:
2012-07-17 01.26.17 by seewhereweland, on Flickr
headers!
2012-07-17 01.29.01 by seewhereweland, on Flickr
a few more pictures of internals; just got the crank out and started cleaning a few things up. the block is still nasty though, hoping naval jelly + wire brushing the hell out of it will be enough for engine enamel to stick.
Untitled by seewhereweland, on Flickr
fresh head!
some of the bearings, these are the 4th, 5th, and 6th from the front.
fresh from the powdercoater!
nasty little buildup on the bottom of one of the bores, below the stroke, must be corresponding to piston wear.
Gotten a lot done recently, with a few delays thanks to forgetting to order rod bearings and somehow completely stripping my oil pump nut (?!). Now the block is cleaned up and painted, crank and pistons are in with new bearings & rings, head is on with new head gasket, and next on the list is getting the timing back together. Pictures below.
Untitled by Marshall H, on Flickr
block paint
I tried to clean up all the sludge caked on the walls of my engine bay (some of which you can see in the first set of pictures) with moderate success.
I also straightened some condenser fins, but a good chunk of 'em weren't really still intact.
more cleaning...
cleaner pistons...
the parts table!
the garage after the head went on.
shiny and clean!
this goddamn thing. I was torquing the oil pump nut to spec when it let go and just started spinning freely. Cut it off with an air cutting wheel to discover that the threads had just peeled right off. back to the dealership I went...
Also there were some weird things going on with the new head bolts: the first part of the torque sequence went fine, but then 3 of the bolts (one by the front of the engine and 2 at the very back) just kept spinning when I got to the second part of the sequence? I put in three of the old ones in those same holes and torqued them down and they did fine. So I think I'm just leaving it that way. Really sketched out by that.
