s50/s52 power!!!
accota
Post by accota »
Would it be possible to place a supra twin turbo kit on a s50??
the kits are sold up to 800rwhp and more
T_C_D
Post by T_C_D »
[QUOTE="accota"]Would it be possible to place a supra twin turbo kit on a s50??
the kits are sold up to 800rwhp and more[/QUOTE]
Supra owners convert to single turbos when they want big power.
BKCowGod3
Post by BKCowGod3 »
but two is more than one. So two must be better.
Yellow2
Post by Yellow2 »
haha, its more complicated getting 2 turbos to run perfect at high HP outputs. Just get one turbo like todd said. My friend is pushing big HP in his supra and i runs a single turbo.
Anything is possible with a litte time and a lot of $$.
accota
Post by accota »
But is it possible to mount the kit on the s50 or s52? does the manifold, pipes and intercooler fit?
there are 1000rwhp supras and s52 so that shouldn't be the problem
if i'm going fot 600-650hp, better way to say: the most hp you can get with 20-25psi, maybe a little bit more. doesn't it be better with a s38 or s50?
the head just isn(t good enough with 2 valves, with the s38 or s50, there are more revves so more spread of the boost needed --->twin turbo
[Edit by accota on [TIME]1132602412[/TIME]]
[Edit by accota on [TIME]1132602582[/TIME]]
T_C_D
Post by T_C_D »
Got to bimmerforums forced induction page. They are all about the M50/S50 etc FI motor.
To answer your question abt fitment. No.
Tjn182
Post by Tjn182 »
you're making it sound like a 800hp supra turbo kit will fit on a bmw engine and make 800hp too, because it's a 800hp kit and stuff.... it doesn't work like that.
but yes - www.bimmerforums.com talks all about the s50/52 engine and turbos
800 HP....................lets get back down to earth here.
We have yet to get one of our FI cars above 400 HP. Now you guys are wanting 800 HP. Lets get to 500 and then 600 HP first (I plan on it) and see how damn scarry the cars are then.
800 is just stupid and will not be usable at all. Its not all about numbers, its about drivability too.
[QUOTE="Duke M535Ti"]We have yet to get one of our FI cars above 400 HP. [/QUOTE]
If memory serves, Todd has.
gol10dr1
Post by gol10dr1 »
i have (at the motor)
Whatever..................just insert 500 HP then. The statement still stands.
T_C_D
Post by T_C_D »
Best I made was 363/427 at the wheels with the stock m30b34. I may put the broken motor on the dyno in ten days. I bet it makes very close to 400rwhp.
Todd
[Edit by TCD on [TIME]1132637461[/TIME]]
[QUOTE="gol10dr1"]i have (at the motor)[/QUOTE]
Andrew,
I still need to get that BIN file from you. I wan t to load it when I am back for R&R.
russc
Post by russc »
right,
The supra guys that make the big hp #s put 10s of thousnads into those engines also. You can't just bolt 800hp to a supra, just like you can't do it to a M30.
[QUOTE="Tjn182"]you're making it sound like a 800hp supra turbo kit will fit on a bmw engine and make 800hp too, because it's a 800hp kit and stuff.... it doesn't work like that.
but yes - www.bimmerforums.com talks all about the s50/52 engine and turbos[/QUOTE]
gol10dr1
Post by gol10dr1 »
actually a supra bottom end has been proven to take 1000 hp on stock internals. of course these guys are using massive turbos, custom amnifolds and intake manifolds and have extensive porting and head work done to achieve these numbers.
BMWJustin
Post by BMWJustin »
I've seen alot more at the wheels.... 666csi...
accota
Post by accota »
what flow is the tcd turbo manifold capable of?
rundatrack
Post by rundatrack »
I think that your going to hate 600...even 500...
I met a person that had a 600 rwhp silvia and hated the shyte outta it ...sold the car like 3 weeks later..he said that he couldnt stick and was just spinning tires constantly...was the most annoying thing ever....
Be careful what ya wish for...
s[QUOTE="Duke M535Ti"]800 HP....................lets get back down to earth here.
800 is just stupid and will not be usable at all. Its not all about numbers, its about drivability too.[/QUOTE]
T_C_D
Post by T_C_D »
[QUOTE="accota"]what flow is the tcd turbo manifold capable of?[/QUOTE]
No idea.
gol10dr1
Post by gol10dr1 »
it has been said that a cast manifold on a bmw can not flow more than 600 hp (not sure if that is whp or crank hp) but i think that has yet to be proven.
Boru
Post by Boru »
Well, that all depends on the casting. A custom tubular manifold can't flow for more than 139hp.... if you use really small tubes.
There's that guy with the turbo e12 that was featured in the Roundel a couple years ago...I seem to remember it made 600hp or something insane like that. How does he do it? I think Adam Wilson in Chicago knows him, maybe he'll see this and provide more info.
Jesse
Post by Jesse »
I'm kinda in agreement with the what's the point comments here. I know that it is just cool to do it and all, but what is the practical side of 600+HP on these cars? The only thing would be regular trips to the track (drag or otherwise) and the gas station I guess. For sure these cars turn heads right now, but I guess they would drop jaws litterally at the track. That's it. Heck with it - I'm going for it too!!! Last one to get to 600CHp is a rotten egg! :p
accota
Post by accota »
what with a GT40R with the tcd kit when the manifold only flows 600hp, then the turbo is just perfect or a little bit to big? I would use somethink like this or with a t61 or a GT35R. what would be the best of these 3 turbos?
i think 600hp is more then enough, that's very quik with only 1500kg to cary and with all that torque.
Boru
Post by Boru »
Jesse, for how long does it have to make 600Hp? ;)
accota
Post by accota »
for always :s, stupid question i guess.
i'm planning to boost at 20-25psi.
think i will get 500-600 out of it.
with cr 8 and vac head and pauter connecting rods on a m30b35
Jesse
Post by Jesse »
[QUOTE="Sweeney"]Jesse, for how long does it have to make 600Hp? ;) [/QUOTE]
Till it blows up of course :p :p
russc
Post by russc »
From what I'm seeing in Turbo Magazine, the supra guys making 800hp+ are almost always re-building the engine(at high $$$). But that engine is a monster, and can take some serious power, as you say.
[QUOTE="gol10dr1"]actually a supra bottom end has been proven to take 1000 hp on stock internals. of course these guys are using massive turbos, custom amnifolds and intake manifolds and have extensive porting and head work done to achieve these numbers.[/QUOTE]
Matt
Post by Matt »
the 1JZ-GTE (mkIV supra TT engine) is indeed a legend. Software, intake, and exhaust make you an honest 400hp on that thing. All of the big supra guys lately are building 3.4 and 3.6L cars with stroker kits to get the torque the supra has always needed.
But, all of these big power supras are "dyno queens". They're undrivable. They dont hook up at the track, street, or strip.
The compression between the 1JZ and the S50 are worlds different. The mounting angles in the car are different. (the Supra doesn't mount its engine slanted like BMW does).
You might consider using the supra information as a starting point (i.e. turbine specs, pipe sizes and lengths, etc), but that assumes that you make your S50 run similar compression pistons and that you make the head flow the same, the cams are similar, etc. I suspect the s50 head flows much better than the supra head.
IOW, you're better off getting an S50 designed system, or designing your own. The supra really has nothing to do with the S50.
