Fresh Built Motor
gol10dr1
Post by gol10dr1 »
alright boys, here's the deal. i take the 535 into my shop back home for some pretty routine stuff, new tranny, fix some wiring, couple of other things. well they put the car up on the lift and my entire undercarriage is soaked in oil! well atleast i wont have any rusting problems with the chassis! so they pull the motor and just about every seal is blown. guess that happens after 233,000 miles and about 10k on boost. everything else inside the motor was in remarkably good condition. i have had significant detonation in the past and when they pulled the pistons, they were spotless, but the rings were well worn. so the decision was made....................BUILD THE MOTOR AND THROW SOME BIG BOOST IT'S WAY! got a few more weeks waiting on parts and then everything will be assembled and i will take it to the tuner and eeek every last bit of hp out of her that we can. here is a list of the new parts going into the block:
mls gasket with stock compression thickness
arp head studs
fresh rod bolts
forged je pistons with upgraded wrist pins and rings w/ 8.0:1 compression
slight boring of the block to make sure the cylinders are true and the new pistons will fit
20+ psi boost!
looking for high 400's rwhp, don't think this turbo can break 500 rwhp but we shall see! :cool: i should have some pictures to post on monday and hopefully the project will be finished with in the next month. let me know what you guys think.
[Edit by gol10dr1 on [TIME]1138405347[/TIME]]
Yellow2
Post by Yellow2 »
sweet plan. i just took my car out today to get fresh premium gas in the motor and do some more tuning. my 7-8psi is plenty nice for me right now. Im sure i can take a lot of the things on the road as I stand wit ha new motor. I cant imagine how 20psi would feel. keep up the good news of the rebuild, and as always, PICTURES are your friend.
altus22
Post by altus22 »
I'm playing with the idea of doing the same thing. What, no VW pistons or b35 head to get that compression? Tell us how it goes.
Great plan!!
Can you send me your BIN file? I want to be running my car on it when I am on R&R leave.
gol10dr1
Post by gol10dr1 »
[QUOTE="altus22"]I'm playing with the idea of doing the same thing. What, no VW pistons or b35 head to get that compression? Tell us how it goes.[/QUOTE]
i got a b35 motor, just need a gasket and pistons to lower compression safely.
duke, i have the bin file now but this one isn't a great tune i dont think. when the motor is done and i break it in for a few days, i am taking it back to my tuner and we are going to spend a whole day tuning it. i will send you that bin file. i feel this one is a little to aggressive for the street or for pump gas. the next one, we will back off the timing a bit and be a touch more conservative on the street tune so i can run it hard all day long with 93 octane.
You think you will be finished by April?
Tjn182
Post by Tjn182 »
Andrew I'm in the saaaame boat. My undercarriage is soaked w/ oil and I have a strong feeling just about every seal is toast. That's why I got new stuff in the oven :)
gol10dr1
Post by gol10dr1 »
[QUOTE="Duke M535ti Backup"]You think you will be finished by April?[/QUOTE]
shooting for the next 4 weeks. pistons should be 3 weeks then after that everything just needs to be assembled.
russc
Post by russc »
Nice,
Your plan of attack is good. 400whp will be easy with that setup. 500whp, I don't know, but I have no experience there is that stratasphere.
Really looking forward to the results.
rundatrack
Post by rundatrack »
Whats going on with the heads.....just old age...
I mean why is there oil on most of ya guys undercarriage?
T_C_D
Post by T_C_D »
[QUOTE="Euro M88"]If J.E. doesn't have the pistons on the shelf, I doubt you get them in 3 weeks. J.E. screwed around for months making the pistons for my M88/3. The first set of pistons weren't produced to my engine builders specifications. He sent them back, the second set was done correctly.
Rich
[Edit by Euro M88 on [TIME]1138527197[/TIME]][/QUOTE]
We have been working on the order since last year. 8 sets are on order and in line for production. I have only received great customer service from them so far.
Todd
gol10dr1
Post by gol10dr1 »
well i had some pics for you guys today but its a good think my guy is a mechanic for a living and not a photographer b/c these pics are piss poor! i am going to call back on monday and see if my boy who works over there can do a better job for me. i cant still post a few of them up as one or 2 are decent pics and will give you an idea of what i am working with. todd, can you by chance host them for me?
