My Supercharged M30b35 build.
Rav335uk
Post by Rav335uk »
Hi guys,
I've been hovering around the forum for about a month, to pick up some hints on the M30's.
I'm not new to these engines, I have one in my E30 convertible now for about 3 years.
But now I have another E30, and thought a complete engine rebuild would be the way to go forward.
Anyway, Pics below, and any advice would be most welcome.
Thanks Rav.
Engine stand bought, went for the 450kg one as there was abotu £5 difference in price.
All assembled.
Engine on and ready for stripping
And this is a few hours later.
Head off, rocker shafts removed, rockers and cam out too.
Head now booked in for Monday for a pressure test and a 1/2mm skim :twisted:
I'll take out the valves on Monday for those eagled eye fookers!
Pistons look to be OK, and the bores look good too, can still see the honing marks on them.
Looks to have been running rick though.
Block will be wired down and painted.
Rav335uk
Post by Rav335uk »
Gave the head in on Monday for a pressure test and skim.
Pressure test was good, and a skim of 4 thou wasa only needed.
Picked it up this morning, removed the valves, and the guides and gave it a quick clean.
Removed the lower timing cover (Covered in years of oil baked on :cry: )
Removed the sump, again covered in years of oil, and got cleaning.
Inspected the chain, all looks good there.
Looked into the chain guides, and there's heavy scoring of both, so new ones will be ordered soon.
Removed the Oil pump and then started on the bottom end.
Brand new Light billet flywheel, takes the E34 clutch.
Rav335uk
Post by Rav335uk »
Looked into the bottom end shells and big end bearings
Not good, slighty worn and will need to be replaced, so ordered they were.
Cleaned up the face with wet'n'dry and taped up.
Removed the shells and crank and pistons
And left it at that.
I started on giving the block a good clean with degreaser and a wire brush attachment onto an electric drill.
All the surface rust and 20 year oil was removed, then washed down with warm soapy water and left out in the sun to dry off.
Then, sprayed Black, covered up all the water inlets, oil inlets, and masked off the block face with masking tape.
The eagle eyes ones will notice the core plugs painted too, don't worry, they;re getting replaced too, just didn't want to replace them sooner, then have to mask them up while spraying the block.
Bought a new proper Dremel 300 this morning{Bluepoint (Snap On) gave up the ghost) :roll: as I wanted to polish the ports.
Thought about it last night and for the hassle, I thought it was worth a bit of effort.
Pics below of the inlet ports, before and after.
Pics aren't the best though.
I'll take some better ones tomorrow.
After
These turned up today too.
Adaptors for the ITB's :D
Sent off a few items to be soda blasted including the throttlebodies, so hopefully should be back soon.
Had the block honed today too, needed doing as there was slight scoring on a few of the bores.
Had a load of parts Soda and media blasted to get rid of all the oil and wax on the parts.
The ITB's were like this
To this
Also, had some head work done in the last few weeks too, thought it would be nice to treat it to a better flow
Had the seats and vlaves cut to 3 angled finishes.
Next new seats, cutter pilot installed.
The first cut at 60* is the bottom cut.
Followed by a 30* top cut, then the seat cut, both are on a double sided cutter. The seat cut is at 46* the two faces will bed in together within the first moments of the engine being started.
This is what you end up with after it has been soda blasted, and all the cuts finished.
A before and after, not alot of difference really as the head had already been scrubbed, but the soda gives it a nice uniform look and doesn't damage the surface of the alloy.
Rav335uk
Post by Rav335uk »
All new chain guides fitted yesterday,
New thrust bearing and shells fitted, dropped the crank in and tightened up the bolts.
For some reason, there was quite alot of end float which was a bit baffling, as everything was measured by using a micrometer :? .
So off came the crank again, the old thrust bearing installed, and then everything reinstalled again, this was to check the origional end float on the crank, cam to 0.005th :?
So, vice versa, new one installed, and for some reason, don't ask, there was reduced crank end float to about 0.002th, so checked and rechecked, phoned a few guys on the Zone to make sure and all is now ok. :D
Oil'd up the bores, and put in all the pistons one by one.
The block was then turned over, new shells fitted and the rest fitted and torqued up as needed.
Decided to take the Oil pump apart and give it a clean before refitting. :D
And fitted.
After a few hours :roll: of freeing up bolts, cleaning faces and general spraying, I ended up from this:-
To this:- :D
The "Eagled" eyed of you will notice it's not the exact same part, but you get the idea :wink:
Only 2 more to go 8O
Thought i'd strip/paint and rebuild the ITB's ready for when they're needed.
And this is the car it's all going into.
Awesome build! I look forward to updates. What supercharger do you plan to use?
skip535i
Post by skip535i »
Sweet build!
Rav335uk
Post by Rav335uk »
Thanks lads.
The supercharger i'm going for is the Rotrex C30-94.
Hopefully, i'll have some more updates this week. :D
espeed
Post by espeed »
subscribed! good stuff :banana:
Rav335uk
Post by Rav335uk »
More updates coming next week, head is being ported to the M88 ITB's atm. :D
Missed a set of BC coilovers a few days ago, so I decided to spend the money elsewhere, and bought this, atleast now I can set the car up to take the Hartge Splits.
Rav335uk
Post by Rav335uk »
Tonights little teaser. :D
Rav335uk
Post by Rav335uk »
And a few more,
That'll be it till next week when I get the head back.
Then i'll try the Stainless Steel 6 branch and see what needs to be done to make it fit.
BMWJustin
Post by BMWJustin »
Very cool project OP, can't wait to see it as it progresses.
Best
Justin
packman21
Post by packman21 »
Rav335uk wrote:More updates coming next week, head is being ported to the M88 ITB's atm. :D
Subscribed! Nice thread.
I would love to have that fender roller. ;) Nice!
Shadow
Post by Shadow »
How much hp do you get with those cuts on the valve?
Rav335uk
Post by Rav335uk »
Not sure on the exact amount.
Someone else who knows could answer that.
silence
Post by silence »
cool build
shocka
Post by shocka »
Great progress, keep it up. :shock:
Rav335uk
Post by Rav335uk »
Not much of an update, but cleaned up the inlet ports after getting the head back from Byron, and then test fitted the ITB's :D
Black Steel
Post by Black Steel »
nice :D
Rav335uk
Post by Rav335uk »
Thanks.
Project is now on the back burner for a while, as my van has eaten up all my engine money. :roll:
pleasefixitup
Post by pleasefixitup »
Rav335uk wrote:Thanks.
What the heck!
I've been following this thread and I just said to myself, "fuck yeah!" because it was updated--I want to see this motor running!
Rav335uk
Post by Rav335uk »
LOL, don't worry, i'm now in the process of clawing some money back for this, as I don't want it to sit doing nothing. :D
Rav335uk
Post by Rav335uk »
Bought these over the weekend :D
Don't worry, there are 4 of them. :laugh:
skip535i
Post by skip535i »
I am so jealous. I will have split ACs one day.....
jrode34m5
Post by jrode34m5 »
Who is making the brackets for rotrex charger if you dont mind
sharing that info.? :cool:
Thanks
J rod
