Controlling blow-by Mann Provent
RDAvena
Post by RDAvena »
So in looking for a better solution to reducing blow-by contamination of the intake and related parts, and not wanting to use the "$29.95 Asia-Pacific special oil catch cans offered on ebay", I found the Mann Hummel Pro Vent kit:
http://www.singhmotorwerks.com/catalog/ ... cts_id=194
It is a low loss, compact design with an integrated synthetic replaceable filter and a drain at the bottom. At $143.00 it is cheaper than the $256.00 they wanted to charge me locally for the same part. It has a small enough footprint so that along with plety of hose it can basically mount anywhere in the engine compartment. Along with the included drain at the bottom you could drain that back to the oil pan or install a valve to drain it when you change your oil. Just some 411 to help with your turbo.
russc
Post by russc »
Do you really need that? I have not seen that on any E28, and have not heard any complaints about oil blow out from the valve cover vent or PCV?
RDAvena
Post by RDAvena »
really needed? No.
Will it help keep the turbo, intercooler, and intake manifold free of oil ? Yes.
You may want to read some of the older posts on Scottie's board on this topic. My recollection Todd even posted a gasoline washout of the intercooler.as a way to reduce oil ingestion. So there is proof that the crankcase ventilation does, over time, deposit an oil film on the inside of these parts.
It may not be your cup of tea, but the post was intended for those that may have a use of such a device.
Boru
Post by Boru »
I get plenty of blowby in the 6er... but then, I'm pretty sure it doesn't have any rings left in it.
I made (of course) a catch-can with drain that's mounted on the driver's side of the bay... pretty easy actually. It works well.
Tjn182
Post by Tjn182 »
russc wrote:Do you really need that? I have not seen that on any E28, and have not heard any complaints about oil blow out from the valve cover vent or PCV?
:laugh: You haven't seen my intake pipes yet have you? :laugh:
Hehe that's probably my problem too 8)
russc
Post by russc »
Well, there you go, everyone has a problem now... ;) Oh, looks like a fine product, go for it.
Velocewest
Post by Velocewest »
Well sure, it's a slick piece. But is it really better than an old coffee can half-full of cat litter?
:shock:
russc
Post by russc »
Velocewest wrote:Well sure, it's a slick piece. But is it really better than an old coffee can half-full of cat litter?
:shock:
:laugh: :laugh: :laugh:
Probably not, but when you open the hood at a meet with a coffee can in there, your can hear "thats ghetto"
papajetta
Post by papajetta »
if u dont have a blow by problem with a m30 your not driving it hard enough...
Monotalonawd
Post by Monotalonawd »
Blow-by is a lot more apparent on turbocharged cars; more pressure inside the cylinders.
On my previous car, I could see exhaust coming out from the valve cover vent hoses if I played a little with the throttle while underhood! :laugh:
The easy way to avoid dirtying up the intercooler, throttle body and intake manifold with engine oil would be to just leave the vent hoses disconnected but I read somewhere that vacuum in the crankcase helps the piston rings seal better.
In that case, a catchcan "connected" to the turbo inlet would provide a steady supply of vacuum. Definetly not legal, but a cheaper way would be to run the vent hoses to the exhaust pipe, after the turbo, where it's supposed to be under vacuum all the time? Maybe someone could confirm?! ;)
DMNaskale
Post by DMNaskale »
It only works on drag cars and only after the mufflers, Moroso and probably others sell kits for it but it is a poor idea for a street driven car. It takes a large amount of exhaust flow and zero restriction in the pipes to be worth a damn. But there is a real benefit when it is set up properly. The exhaust pipe will never be under vacuum, but if the kit is hooked up right, a venturi is created that provides a vacuum in the vent line and pulls the crankcase gases into the exhaust.
Monotalonawd
Thanks for the info! :up:
I saw a kit at Summit Racing but wondered why not many people were running it! :D
papajetta
Post by papajetta »
before it was mentioned here i was actually toying around with a set up that wouldn't need a can.
i got one of those one way valves that the gm cars use on the secondary air injection system ( inlet and outlets about 5/8 in diameter) and just tapping it onto the top of my valve cover.
this would be located behind the valve cover baffle.
and routing that towards the intake
this way i wouldn't need to be draining any oil out.
Shawn D.
Post by Shawn D. »
I'd bet Russ doesn't like the idea because Dinan didn't use one! ;)
RDAvena
Post by RDAvena »
Shawn D. wrote:I'd bet Russ doesn't like the idea because Dinan didn't use one! ;)
I can epoxy the Dinan pin I recieved from the 5erFest goodie bag and resell :laugh:
russc
Post by russc »
Yup, you can mess with perfection 8)
People have made lots of money doing just that :laugh:
Shawn D.
Post by Shawn D. »
Yes, you certainly can mess with "perfection," as you're doing by putting in an M30B35 and re-doing the engine management!
I suspect you meant to say "can't"! :)
So, can you or can you not mess with perfection, and if you can mess with perfection, why would you when it's perfect? :lol:
russc
Post by russc »
Ya, "can't". Im typing to fast to be of any use today. And Im too lazy to proof my post today. Just making light converstion. I really don't care that much either way on Dinan. Just getting upidy with the group.
