How too controal boost level?
I have a 745i turbo setup. I believe the boost is set at 8 psi. on the stock application. I have heard that it can be changed with a new spring inside the wastegate. I have also heard it can be changed with a standard boost controller. Can anybody with experience in this tell me how it can be done. I realize that with changing boost level I will need fuel upgrades. thanks for your help
Yeah - the 745i ecu only causes troubles...
I'm running 10psi flat right now, but my wastegate has begun to wear a little. I tapped the top chamber, sealed it off, and now I blow boost into there -- it keeps my boost right at 10psi. I'm pretty sure I can bump it to whatever I want... but I'd rather have a more "mechanical" way of adjusting it.
Look at my website, the 059 DME is scalable to 1000hp. But it doesn't monitor boost like the m106 system.jimbixjr wrote:what about the ecu out of an 86 535i 3.4l manual car? I have heard its around 10 psi but you can do more with an fmu and a chip that retards timing without getting a full standalone system for fuel and spark..??????
I haven't seen a 745i wastegate but if it's activated via a pressure hose, you can use an "adjustable check valve" as a cheap manual boost controller. I used it with great success on my turbo dsm!
http://www.gusmahon.org/html/boostcontrol.htm
Take a moment to visit the site; it's about the old turbo Mopars!
The 745i wastegate acts quite different from other wastegates...Monotalonawd wrote:I haven't seen a 745i wastegate but if it's activated via a pressure hose, you can use an "adjustable check valve" as a cheap manual boost controller. I used it with great success on my turbo dsm!![]()
@ 10 psi it will open and no boost controller will change that.
