Finally finished the cooling system rebuild/alternator replacement job on the Ti. That is the job from hell.
Let it idle in the driveway for a good 40 minutes while cleaning up, and the temp gauge never went past 12 o'clock.
To make the job even more difficult, my son's small GearWrench ratchet and a 7mm socket dropped down behind the engine and didn't fall out. Can't reach it, can't see it with mirrors, can't get a magnet on it... Gonzo. Blew at least an hour looking for the dadgum thing.
davintosh wrote:Finally finished the cooling system rebuild/alternator replacement job on the Ti. That is the job from hell.
Congrats. I always dread not hearing that final thud on the driveway.
I've decided to hold out for the perfect ti swap car: either a late 328i(s), a Z3 with a good rear subframe, or an M3 that's not made of gold. I think I'll be in for a long wait.
On the M5 front(cracked endcap), got most of the radiator stuff in today. The more I look at it the more things I want to do "while I'm in there."
ADD sucks.
Oops; let the dancing banana out too soon on this one. After writing that last bit, I went out and caught a whiff of raw gasoline. Put a finger under where the fuel line attaches to the fuel rail... wet. Off with the upper intake mani, tighten, check, tighten, check, tighten, check, tighten, check, remove... Guess what? Missing o-ring. Damn. Howtheheckdidimissthat? Another hour.davintosh wrote:Finally finished the cooling system rebuild/alternator replacement job on the Ti. That is the job from hell.
This car is seriously testing my sanctification.
I hope this is the end of the 318Ti saga... I decided yesterday that the car should stay here for a few days, just to make sure no other little problems cropped, and if they did, so I could take care of them. Went out to drive it to the doc's office (weekly PICC line dressing change) and it wouldn't start; battery was dead. I had wondered whether the dying alternator might have damaged the battery...
After my appointment I checked the battery voltage, and it was down to about 10 volts. Jump started the car and when running showed about 14.5 volts at the terminals. Drove the car to Batteries Plus, and the battery tested bad, so $118 later, it's all better.
Tonight I broke down and took the winter tires off and put the summer treads on. If it snows in the next few days, I'll accept full responsibility.
After giving batteries plus 3x to rebuild my DeWalt battery and them failing 3x, I won't go there anymore.davintosh wrote:I hope this is the end of the 318Ti saga... I decided yesterday that the car should stay here for a few days, just to make sure no other little problems cropped, and if they did, so I could take care of them. Went out to drive it to the doc's office (weekly PICC line dressing change) and it wouldn't start; battery was dead. I had wondered whether the dying alternator might have damaged the battery...
Honestly, I've had good luck with kragen/oreilly's batteries
Giving thought to buying another one, if only to steal the seats, fix it, and flip it. This car came up for sale on the local CL yesterday, so I gave the seller a call & stopped by for a look yesterday.
Not sure if the CFO will give the nod on this one, but I think it's worth a try if I can talk it down a couple hundred $$. Might be good to rescue one this once! Or a good object lesson.
The overheating problem appears to be an improper cooling system purge; the owner has had a joe-blow shop working on the car, and the mechanic admits to knowing nothing about BMWs. There's no oil in the coolant or vice-versa, and no weird crankcase pressure problems. Car runs & pulls decently (for an auto) and drives well. New tie rods are on it, and it was just aligned. The wheels are butt-ugly and would definitely be swapped out with a set of Style 2s, and these things sold separately. The body is in decent shape; one ding with surface rust near the right rear tail light, and the usual door-bottom rust, but not bad. I couldn't get the shifter to go down any lower than S3(? don't know the slushboxes) but also noticed about $5 in change rattling around below the console, probably gumming things up. The big appeal is the leather; it's nearly perfect, if heavily coated with ghetto shine. I've learned that the e34 front seats will bolt up in an e32 (which is where I'd like to put them), but the wiring may differ slightly between the two. My car has a parchment interior, and this one has schwartz, which is ultimately what I'd love to have in my car. The rear seat won't fit -- at least without leaving some ugly gaps -- but I figure a decent schwartz rear seat will be easier to find than fronts.1995 BMW 525i - $700 (SIOUX FALLS SD)
THIS BMW RUNS GOOD BUT IT GETS HOT SOMETIMES.IT HAS OVER 350.00 WORTH OF NEW PARTS ON IT.IT HAS POWER LEATHER SEATS- SUN ROOF-MIRRORS-WINDOWS.COME TAKE IT FOR A DRIVE AND AND MAKE AN OFFER.PLEASE CALL BILL (do not text). @ 605-xxx-xxxx
It was a couple of days ago, but I washed the E12. The project one. And I looked inside and the the drivers seat was wet! WTF, the car didn't leak all winter and now it leaks from washing it? Motored the sunroof back and sure enough the drain was plugged. I tried some #12 stranded. Then doubled up. I pulled the splash guard. Hit it with 60PSI of air. Nothing. No progress at all. Finally cranked up the compressor to 140PSI. That worked. Then it wouldn't close, the sunroof clutch is worn and needs adjustment. Oh, did I mention project?:roll: Did something else too, but after battling the drain for an hour I can't remember what.
Installed my front seats.
Not that it matters, but I can say that they are probably the only pair or one of very few at least of Light Silver Grey e34 manual sport seats on US soil.
They aren't perfect, but manual sport seats are sooo darn cool!
'Scuse the crappy pic, I was in a bit of a rush to get to work.
I missed out on the e34 deal; probably a good thing, I guess. Oh well.
Friday my eldest son & I tore into the rear end of the wife's X5; I knew that things were worn when we bought it, what with the fat-lady-on-heels excessive negative camber on the rear wheels. So I ordered new control arms, ball joints, integral links & wheel bearings for it (a persistent growl from the rear wheels too) last fall, but didn't get around to the job until now. Things went well tearing the right side apart, and we high-fived when we finally got the inner bearing race off the wheel hub around noon, because that meant we could start putting things back together on that side. I took a little break, and when I went back out to the garage, my son had the new bearing pressed onto the hub. Backwards. Not sure why he didn't wait for me or check the diagrams or look at the assembly to figure it out, but... Unfortunately, without some seriously specialized equipment it's not possible to get the bearing off the hub without destroying it. $60 lesson.
I took it better than he did; finally had to tell him to stop with the beating himself up over it. His mom isn't upset over the deal; it just means that he'll have to come back for another Friday/Saturday wrenchfest to finish the left side when the replacement bearing gets here. In the meantime I think I'll clean up the bearing, have it engraved with something funny about lessons learned, and frame it for him.
Picked up a '99 328is yesterday. It was "drifted" into a tree, well at least one tree. It has a lot of really nice pieces but I'm not too sure about those wheels. lol
I've removed a few engines over the years, parting out E28s, but I didn't have to put everything back in the right place! I have J!m's Guide and a ton of info on the ti website so I think I'm prepared for the fun ahead.
Yah , I haven't even had to pull a head . I yanked a few engines, mostly for practice.djazz wrote:Picked up a '99 328is yesterday. It was "drifted" into a tree, well at least one tree. It has a lot of really nice pieces but I'm not too sure about those wheels. lol
328ti? Sweet.djazz wrote:Picked up a '99 328is yesterday. It was "drifted" into a tree, well at least one tree. It has a lot of really nice pieces but I'm not too sure about those wheels. lol
the 240 wagon
recently installed:
rebuilt cylinder head, ARP stainless studs
t-belt, w-pump, etc.
manifold-back replacement exhaust
radiator
e-fan
now doing gauges while waiting on the wheel adapters for 5x120 wheels...
radiator
e-fan
