Euro 535i LS Turbo Build Thread - 7/10/19 Dyno update
Mark 88/M5 Houston
Post by Mark 88/M5 Houston »
Pretty!! ;)
heinrich535i
Post by heinrich535i »
45 seconds huh?
T_C_D
Post by T_C_D »
I am contemplating yanking the heads this week and taking to a local machine shop for freshening.
I am purchasing a new cam, lifters, push rods and rocker upgrade all to support a reliable 7k rev limit.
ACHTUNG
Post by ACHTUNG »
Any status updates?
T_C_D
Post by T_C_D »
ACHTUNG wrote:Any status updates?
Beat me to it by a few days. Update soon.
mkoepp
Post by mkoepp »
I saw this car yesterday. It is truly a work of art. Great job and hats off to the TCD Team. :bow:
T_C_D
Post by T_C_D »
I finally am able to prioritize the e28. Hope to drop the heads off today at the machine shop.
Shadow
Post by Shadow »
T_C_D wrote:
I am buying a new oil pump and will inspect the pick up assembly.
U find anything?
Just started it up and saw there was no oil pressure for some time? strange stuff.
T_C_D
Post by T_C_D »
Dropping heads off at machine shop in the morning. Should have the block and tranny out on Friday.
Ju@n
Post by Ju@n »
Wow
Without the heads that looks like you have a ton of space! jeje
You'll have a better weight balance distribution, since now the engine sits almost completely behind the front wheels
T_C_D
Post by T_C_D »
Dropped the heads off today. Will have them back early next week. Ordered the oil pump and gaskets today as well.
Christopherjason
Post by Christopherjason »
Now i Really want a Ls Motor in my E28 i need a new motor either way and a Stock LS (250-350) area sounds like a Nice stock Build and a nice power for these !
Phoenix
Re: Euro 535i LS Turbo Build Thread
Post by Phoenix »
I just joined this forum to comment on this build. I love it!!! I have a lot of experience with the LSx platform and I can say that a built bottom end can take 15-18 psi comfortably as long as you have the fuel to feed it and don't go too crazy with the timing.
T_C_D
Post by T_C_D »
Maybe this weekend. :|
Bill in MN
Post by Bill in MN »
Well, now you will have something to drive over here this Fall :)
Great to see you back at it.
T_C_D
Post by T_C_D »
Finally some progress. I was ready to install the heads but couldn't find the pins that locate the cyl head. Bottom end is buttoned up.
Recap:
99mm bore
82.8 mm stroke
5.1L
9.5CR Forged pistons
Cam specs image below
Stock freshly rebuilt 799 heads (LS6)
LS7 lifters
Comp Cams pushrods
Trunion kit for rocker arms
Safe 7k rev limit. Peak HP at 6500rpm, in theory anyway. Planning to run 10psi for whatever it yields.
Brian D
Post by Brian D »
T_C_D wrote: Recap:
100mm bore
90mm stroke
5.1L
Typo on displacement? http://www.bgsoflex.com/cgi-bin/displac ... illimeters
Looks like fun though!
T_C_D
Post by T_C_D »
Brian D wrote:
T_C_D wrote: Recap:
100mm bore
90mm stroke
5.1L
Corrected. Thanks.
Brian D
Post by Brian D »
3.25 (ish) stroke, shades of the old 327! Takes me back...
bornagain
Post by bornagain »
Hey todd, this is awesome, pure motivation for me to get back at the car, except im not sure what i want to do now. i do have a couple questions though and forgive me if i missed it but what tranny are you using and what is the new engine classed as? ---- Never mind about the trans question, just saw where it said T56, not sure why but read that as the turbo the first time around.
T_C_D
Post by T_C_D »
bornagain wrote:Hey todd, this is awesome, pure motivation for me to get back at the car, except im not sure what i want to do now. i do have a couple questions though and forgive me if i missed it but what tranny are you using and what is the new engine classed as? ---- Never mind about the trans question, just saw where it said T56, not sure why but read that as the turbo the first time around.
It's a Gen 3 LS motor. Block is a 2005-2007 L33 Aluminum 5.3. Bore is 99.1108mm. Crank and rods are from a 4.8 LS
Touched it today.
T_C_D
Post by T_C_D »
Almost ready to install. Need to install the harmonic balancer and plug the oil dipstick tube in the block. I am using a dipstick in the oil pan.
bkbimmer
Post by bkbimmer »
Where did you get the LS plastic Dummy Block? I would like to get one for mock up in my e12.
T_C_D
Post by T_C_D »
bkbimmer wrote:Where did you get the LS plastic Dummy Block? I would like to get one for mock up in my e12.
I borrowed it from a friend but they are available everywhere. Try summitracing.
T_C_D
Post by T_C_D »
Finally moving forward.
Greg E34
Post by Greg E34 »
YES!
M. Holtmeier
Post by M. Holtmeier »
Greg E34 wrote:YES!
+1 !
M. Holtmeier wrote:
Greg E34 wrote:YES!
+1 !
+2 !!
NICE! About time, thought you were turning into another Rich In Houston :laugh:
