Post by rmiddendorf »
geordi wrote:Image
Bought these nice Hartges from Graham. Picked up from refinishers today. Ronald says sweet!
Now only need new decals for center caps...any recommendations on a supplier?
Does BavAuto have them? They're not usually my first go to but I've seen them in their catalogs.
Greg E34
Post by Greg E34 »
rmiddendorf wrote:
geordi wrote:Image
Really? I've been looking for decals for my Hartge's for several years. Never have seen them at Bavauto (or anywhere else).
Chimi-Changa
Post by Chimi-Changa »
I bought these off Cactusjacks1 for 29 bucks on this board, Have not used yet as they are slightly smaller, and different color than original ( think he makes):
geordi
Post by geordi »
I can find the black background with blue & black Hartge logo. Would prefer the older silver logo :|
geordi
Post by geordi »
Ooh! If yours are 48mm & selling, I'll take 'em ! :D
L_N_Love
Post by L_N_Love »
M5 has been in the garage because I just washed it and now it is raining and snowing. Stay clean my friend.
djazz
Post by djazz »
Hartges are near the top of my preferred list.
Congrats. :up:
geordi
Post by geordi »
Installed the powder coated struts and new wheel bearings!
geordi wrote:Image
That's beautiful.
Acid House
Post by Acid House »
The rattle over bumps that started a few days ago from the front driver's wheel got worse, so I jacked it up and had a look around.
I must have lost the brake retainer clip over a pothole at some point, and now the 7mm hex pins on the caliper were both backing out from further pothole shaking. Thing was rattling like crazy by now :oops:
Tightened them up real nice and grabbed a new clip from the yard. Quiet as a mouse now so I don't sound like a hoopty going down the road :D
davintosh wrote:
geordi wrote:Image
That's beautiful.
Understatement of the year. :shock:
Mab1957
Post by Mab1957 »
Oil change and reset SI. I need those ^^ a set of front irons and one of slammin's rebuilt rear subframes for the Alpin 535is.
Took a photo of it.
Das_Prachtstraße wrote:Took a photo of it.
:pics!:
:pics!:
Down the bottom!
Dusted the snow off of it. It hasn't moved for about a week, and a couple of inches' worth has collected on it. I really need to do something to shine that thing up. When it warms up, in the spring.
Hffvdbl
Keyless Entry
Post by Hffvdbl »
I added the JC Whitney keyless entry I bought six months ago. Wow, what an easy life-changing job. Another "thanks to myE28" for the endless knowledge base that is this board!
rollcentre
Post by rollcentre »
Trunk gasket installed! Por-15 a little spot of rust.
Now to figure out if i need any RTV sealant...
DanOKC
Post by DanOKC »
Installed new drivers door lock & finished install of cruise
control previous owner had removed.
Acid House
We climbed up some mountains!
(you can kinda see it perched triumphantly on the far right)
Whoah huge pic...
waynet1
Post by waynet1 »
Acid House wrote:We climbed up some mountains!
Whoah huge pic...
It very well is a huge picture, however, beautiful. :up:
That would make a great jigsaw puzzle. Difficulty level=extreme.
Took Glenn (azure) for a drive in it. Not helpful when trying to sell him an e34 Touring. :laugh:
Acid House
Whoah huge pic...
I will say this; if you think a 528e is slow normally, try taking it to 12,000 ft :rofl:
I cleaned the sunroof drains on my 528e hoping they might have been the cause of this:
They weren't.
I also replaced the heater control valve on my 535is with a brand new OE unit. The original came completely apart and the rebuild kits suck.
cek wrote:I cleaned the sunroof drains on my 528e hoping they might have been the cause of this:
They weren't.
Why do you dislike the rebuild kit? I haven't done one ever but am interested in knowing why so if I have to I can make an educated decision on how to proceed.
JSmoove
Post by JSmoove »
Today the '86 535i got the following
Shiny new fuse box cover-super easy to replace.
Shiny new head light/fog light switch support- supper easy to replace (geez these things are flimsy though).
Shiny new brake bomb-Not the hardest thing I've ever done, but man no matter how easy you think a project will be something always creeps up and makes it a pain.
First off the two lines near the firewall would not break free for the longest time. Eventually got them off and the bomb swapped. Then I had almost everything buttoned up and the 19mm high pressure line would not thread into the regulator for the life of me. Ended up having to remove the two low pressure lines and mounting bolts again to get it positioned right for the line to thread. What I've read and thought would take maybe 1.5-2 hours ended up taking me 3. This was my first bomb replacement so maybe I get a pass this time?
I went out and did my monthly run of Heinz. He was a little slow on startup but otherwise did fine. Its always difficult to not pull him out for a drive everytime I do that.
rmiddendorf wrote: Why do you dislike the rebuild kit? I haven't done one ever but am interested in knowing why so if I have to I can make an educated decision on how to proceed.
Everybody says the rebuild kits don't last for shit. I certainly was not impressed with the quality/feel of the rubber in the one I bought for Maytag. Vlad's a keeper so I don't mind paying for a part that I know will last in a situation like this.
BuzzBomb
Post by BuzzBomb »
I've had a mystery vibration for a while now. It seems like it started about eight months after getting my tires mounted. I've had them rebalanced a few times now, and it hasn't helped(my rotors are fine).
I have a whole new respect for America's Tire store. I bought my tires there originally and got the lifetime balance option. After the third time back with the same issue, they finally offered to "balance match" my wheels and tires. What this means is they find the heaviest side of both the tire and wheel, and oppose them. Then they do their standard balance. It solved everything. You'd think that balance is balance, but it seems not. It's more work, so I get it that they don't offer it on every install, but in my case, it did the trick. I'll always get this done from the beginning now.
The Bosch ones used to be decent and lasted a few years at least. Bosch stopped selling the insert as a repair kit though, and the repair kit brand available now is shit. If it works at all, it doesn't seem to stay that way longer than a year. Most of the time it fails sooner.
