Hello everyone,
I have an E34 M5 with a S38 B38 engine. I am slowly walking the turbo route and my clutch has died.
I will replace the Flywheel with the S38 B36 Single Mass flywheel (surfaced).
I am interested in the -765 Sachs PP for its holding capability and availability in EU. However I don't know the best clutch to use.
I would like to hold as much tq as possible, with some drivability, so maybe I should avoid the puck sinter metallic.
Is there any clutch you would reccommend? Sprung Hub?
Thanks,
Paulo
Best Clutch for -765 Sachs PP
Re: Best Clutch for -765 Sachs PP
Clutch masters kevlar disk has worked well for years of abuse.
marc
marc
At what torque level? Any drivability issues?
Do you have a link for that clutch? Is it sprung hub?
Mine is a full circle disk w/ spring hub, and clutch masters pp. I was surprised how light the pedal was after trying a spec stage 2 . I'm maxing out my m106 /k27 at 18# somewhere around 325hp /325 torque and I abuse it every chance I get. I've had it for several years now and highly recommend.
marc
http://www.clutchmasters.com/
marc
Thanks. However I will need a stronger solution for around 800nm-1000nm.
I am looking for a sprung hub, marcel Spring, multi puck clutch with some aggressive material, either ceramic or sintered...
Besides clutchmasters, what would you recommend?
765 with oem disc is MORE than enough for a B38,,,, N/A
i think the Sachs 765 is one of the best press that is around,,
but you could also go ..http://www.specclutch.com/cars/BMW/M5/1992/Single if you want to go heavy duty F/I
