e23 1981 L - jet into my 1984 533i
belitwo
Post by belitwo »
Hey guys. I currently have the motronic e23 84 - 86 turbo set up for about 5 years and have nerver attemptted to intall into my 533I do to my lack of knowledge of turbos But this week I just purchased a complete running e23 1981 turbo L _ jet. And I am not trying to be lazy I have been searching and most that I find is for motronic swap and that is why I am here asking for some guidance please it would be greatly appreciated. Thanks
marc79euro645
Re: e23 1981 L - jet into my 1984 533i
Post by marc79euro645 »
I had an 81 m30b32 m102 in my original swap. m30b34 is better( more cc's and higher compression). I kept the charge piping from the m102 with the recirculating design BOV.
IMHO Ditch the motronics and Ljet and go Megasquirt .
Scotty Sharpes 745 site is a great resource of info on m102 and m106
http://bmwturbos.scottiesharpe.com/
Good luck
marc
belitwo
Post by belitwo »
I had searched this same website with no luck. But finally found it on the 545i section second page. Convertion on from l - jet to motronic.
Thank you Mark. Time to do so studying
belitwo
Post by belitwo »
I have one more question the e23 under high RPM the car back fires and RPM neddle goes up and down crazy. What could this be?
marc79euro645
AFM maybe. Thats one of the best things about megasquirt, ripping out that **** AFM.
belitwo wrote:I have one more question the e23 under high RPM the car back fires and RPM neddle goes up and down crazy. What could this be?
I have seen this caused by several things. It can be a severe boost leak on an AFM or MAF based system. I would build a boost leak tester and make sure you have NO leaks. It can be igntion blowout which will feel much like a hard spark cut. What kind of gap are you running? This sounds like another case where Megasquirt would make life so much easier.
belitwo
Post by belitwo »
The AFM has been messed with I do have AFM from the motronic set up would it work on the l-jet?
And megasquirt would be nice but it looks like a lot of homework.
And what do you mean by gap?
Thanks guys
belitwo
Post by belitwo »
AFM. It was guys. I opened it and was able regulate the RPM as they where high and got rid of the back fire and erratic RPM needle.
Thanks a lot. Really appreciate it
belitwo wrote: And what do you mean by gap?
Glad you got it sorted. Sorry I wasn't more clear - I was talking about spark plug gap. Spark blowout from too large a gap/not enough ignition energy will cause bucking and hesitation.
